cs_equation_bc.cpp File Reference
#include "base/cs_mem.h"
#include "bft/bft_printf.h"
#include "base/cs_array.h"
#include "cdo/cs_cdo_toolbox.h"
#include "cdo/cs_cdo_turbulence.h"
#include "cdo/cs_evaluate.h"
#include "cdo/cs_xdef.h"
+ Include dependency graph for cs_equation_bc.cpp:
Macros
#define CS_EQUATION_BC_DBG   0
static void _init_cell_sys_bc (const cs_cdo_bc_face_t *face_bc, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys)
 Set members of the cs_cell_sys_t structure related to the boundary conditions. Only the generic part is done here. The remaining part is performed specifically for each scheme. More...
static void _init_cell_sys_macfb_bc (const cs_cdo_bc_face_t *face_bc, const cs_cell_mesh_t *cm, const cs_macfb_builder_t *macb, cs_cell_sys_t *csys)
 Set members of the cs_cell_sys_t structure related to the boundary conditions. Only the generic part is done here. The remaining part is performed specifically for each scheme. Only for MAC-fb scheme. More...
static void _assign_vb_dirichlet_values (int dim, int n_vf, const cs_lnum_t *lst, const cs_real_t *eval, bool is_constant, cs_real_t *vvals, int counter[])
 Set the Dirichlet BC values to the face vertices. Case of vertex-based schemes. More...
static void _sync_circulation_def_at_edges (const cs_cdo_connect_t *connect, int n_defs, cs_xdef_t **defs, cs_lnum_t def2e_idx[], cs_lnum_t def2e_ids[])
 Synchronize the boundary definitions related to the enforcement of a circulation along a boundary edge. More...
void cs_equation_bc_init_boundary_flux (cs_real_t t_eval, const cs_cdo_quantities_t *cdoq, const cs_equation_param_t *eqp, cs_real_t *values)
 Set the values for the normal boundary flux stemming from the Neumann boundary conditions (zero is left where a Dirichlet is set. This can be updated later on) More...
void cs_equation_bc_set_cw_vb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_flag_t vtx_bc_flag[], const cs_real_t dir_values[], cs_real_t t_eval, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Set the BC into a cellwise view of the current system. Case of vertex-based schemes. More...
void cs_equation_bc_set_cw_eb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Set the BC into a cellwise view of the current system. Case of edge-based schemes. More...
void cs_equation_bc_set_cw_fb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Set the BC into a cellwise view of the current system. Case of CDO Face-based schemes. More...
void cs_equation_bc_set_cw_macfb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_macfb_builder_t *macb, cs_cell_sys_t *csys)
 Set the BC into a cellwise view of the current system. Case of MAC Face-based schemes. More...
void cs_equation_bc_set_cw_cb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Set the BC into a cellwise view of the current system. Case of Cell-based schemes. More...
void cs_equation_bc_set_vertex_flag (const cs_cdo_connect_t *connect, const cs_cdo_bc_face_t *face_bc, cs_flag_t *vflag)
 Define an array of flags for each vertex collecting the flags of associated boundary faces. More...
void cs_equation_bc_set_edge_flag (const cs_cdo_connect_t *connect, const cs_cdo_bc_face_t *face_bc, cs_flag_t *edge_flag)
 Define an array of flags for each edge collecting the flags of associated boundary faces. More...
void cs_equation_bc_dirichlet_at_vertices (cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, cs_flag_t *bcflag, cs_real_t *values)
 Compute the values of the Dirichlet BCs at mesh vertices. This is done for CDO vertex-based and CDO vertex+cell-based schemes. More...
void cs_equation_bc_dirichlet_at_faces (const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, cs_real_t t_eval, cs_real_t *values)
 Compute the values of the Dirichlet BCs at boundary faces. This can be applied to CDO face-based schemes (DoFs are attached to primal faces), to CDO cell-based schemes or even to FV schemes. More...
void cs_equation_compute_neumann_svb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
 Compute the values of the Neumann BCs when DoFs are scalar-valued and attached to a vertex-based schemes (Vb or VCb) Case of the Neumann BCs i.e. Neumann is defined by a scalar. More...
void cs_equation_compute_full_neumann_svb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
 Compute the values of the Neumann BCs when DoFs are scalar-valued and attached to a vertex-based schemes (Vb or VCb) Case of the full Neumann BCs i.e. Neumann is defined by a vector. More...
void cs_equation_compute_neumann_sfb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
 Compute the values of the Neumann BCs when DoFs are attached to the face f. Case of scalar-valued equation (not full Neumann BCs) More...
void cs_equation_compute_full_neumann_sfb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
 Compute the values of the Neumann BCs when DoFs are attached to the face f. Case of scalar-valued equation with a full Neumann BC definition. More...
void cs_equation_compute_neumann_vfb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
 Compute the values of the Neumann BCs at the face f when DoFs are attached to faces. Case of vector-valued equation (not the full Neumann) More...
void cs_equation_bc_cw_robin (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *rob_values)
 Compute the values of the Robin BCs for a face (cell-wise compute relying on the cs_cell_mesh_t structure) More...
void cs_equation_bc_cw_turb_smooth_wall (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_real_t nu, const cs_real_t kener, const cs_real_t hfc, const cs_real_t *uc, double *rob_values)
void cs_equation_bc_circulation_at_edges (cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, cs_real_t *values)
 Compute the values of the circulation along primal edges lying on the domain boundary (the integral of the tangential component of vector-valued field). This is used for CDO edge-based schemes where DoFs are attached to (primal) edge-based schemes. More...
void cs_equation_bc_update_for_increment (cs_cell_sys_t *csys)
 Update the boundary conditions to fullfill the constraint when an incremental solve is set. More...
◆ CS_EQUATION_BC_DBG
◆ _assign_vb_dirichlet_values()
static void _assign_vb_dirichlet_values ( int  dim,
int  n_vf,
const cs_lnum_t *  lst,
const cs_real_t *  eval,
bool  is_constant,
cs_real_t *  vvals,
int  counter[]
static
[in]dimnumber of values to assign to each vertex
[in]n_vfnumber of vertices in a face
[in]lstlist of vertex numbering
[in]evalresult of the evaluation to set
[in]is_constantsame value for all vertices ?
[in,out]vvalsvertex values to update
[in,out]countercounter to update
◆ _init_cell_sys_bc()
static void _init_cell_sys_bc ( const cs_cdo_bc_face_t *  face_bc,
const cs_cell_mesh_t *  cm,
cs_cell_sys_t *  csys
inlinestatic
[in]face_bcpointer to a cs_cdo_bc_face_t structure
[in,out]csyspointer to a cs_cell_system_t structure
◆ _init_cell_sys_macfb_bc()
static void _init_cell_sys_macfb_bc ( const cs_cdo_bc_face_t *  face_bc,
const cs_macfb_builder_t *  macb,
inlinestatic
[in]macbpointer to a cs_mac cs_macfb_builder_t
◆ _sync_circulation_def_at_edges()
static void _sync_circulation_def_at_edges ( const cs_cdo_connect_t *  connect,
int  n_defs,
cs_xdef_t **  defs,
static
[in]n_defsnumber of definitions
[in]defsnumber of times the values has been updated
[in,out]def2e_idxindex array to define
[in,out]def2e_idsarray of ids to define
◆ cs_equation_bc_circulation_at_edges()
void cs_equation_bc_circulation_at_edges ( cs_real_t  t_eval,
const cs_mesh_t *  mesh,
cs_real_t *  values
[in]t_evaltime at which one evaluates the boundary cond.
[in]eqppointer to a cs_equation_param_t
[in,out]valuespointer to the array of values to set
◆ cs_equation_bc_cw_robin()
void cs_equation_bc_cw_robin ( cs_real_t  t_eval,
short int  def_id,
short int  f,
double *  rob_values
[in]def_idid of the definition for setting the Neumann BC
[in]flocal face number in the cs_cell_mesh_t
[in,out]rob_valuesarray storing Robin values to use
◆ cs_equation_bc_cw_turb_smooth_wall()
void cs_equation_bc_cw_turb_smooth_wall ( cs_real_t  t_eval,
short int  def_id,
short int  f,
const cs_real_t  nu,
const cs_real_t *  uc,
double *  rob_values
[in]nulaminar kinematic viscosity
[in]kenerturbulent kinetic energy
[in]hfcdistance from cell center to the wall
[in]ucnorm of tangential components of cell velocity
◆ cs_equation_bc_dirichlet_at_faces()
void cs_equation_bc_dirichlet_at_faces ( const cs_mesh_t *  mesh,
cs_real_t  t_eval,
cs_real_t *  values
◆ cs_equation_bc_dirichlet_at_vertices()
void cs_equation_bc_dirichlet_at_vertices ( cs_real_t  t_eval,
cs_flag_t *  bcflag,
cs_real_t *  values
Compute the values of the Dirichlet BCs when DoFs are attached to vertices.
[in,out]bcflagpointer to an array storing type of BC
◆ cs_equation_bc_init_boundary_flux()
void cs_equation_bc_init_boundary_flux ( cs_real_t  t_eval,
const cs_cdo_quantities_t *  cdoq,
cs_real_t *  values
◆ cs_equation_bc_set_cw_cb()
void cs_equation_bc_set_cw_cb ( const cs_cell_mesh_t *  cm,
cs_cell_sys_t *  csys,
cs_cell_builder_t *  cb
Set the BC into a cellwise view of the current system. Case of Face-based schemes.
[in]cmpointer to a cellwise view of the mesh
[in]dir_valuesDirichlet values associated to each vertex
◆ cs_equation_bc_set_cw_eb()
void cs_equation_bc_set_cw_eb ( const cs_cell_mesh_t *  cm,
◆ cs_equation_bc_set_cw_fb()
void cs_equation_bc_set_cw_fb ( const cs_cell_mesh_t *  cm,
◆ cs_equation_bc_set_cw_macfb()
void cs_equation_bc_set_cw_macfb ( const cs_cell_mesh_t *  cm,
[in]dir_valuesDirichlet values associated to each faces
[in,out]macbpointer to a cs_macfb_builder_t strucuture
◆ cs_equation_bc_set_cw_vb()
void cs_equation_bc_set_cw_vb ( const cs_cell_mesh_t *  cm,
cs_real_t  t_eval,
[in]vtx_bc_flagBC flags associated to vertices
◆ cs_equation_bc_set_edge_flag()
void cs_equation_bc_set_edge_flag ( const cs_cdo_connect_t *  connect,
cs_flag_t *  edge_flag
[in]face_bcpointer to a structure collecting boundary conditions applied to faces
[in,out]edge_flagBC flag on edges to define
◆ cs_equation_bc_set_vertex_flag()
void cs_equation_bc_set_vertex_flag ( const cs_cdo_connect_t *  connect,
cs_flag_t *  vflag
[in,out]vflagBC flag on vertices to define
◆ cs_equation_bc_update_for_increment()
void cs_equation_bc_update_for_increment ( cs_cell_sys_t *  csys)
[in,out]csyspointer to the cell system structure
◆ cs_equation_compute_full_neumann_sfb()
void cs_equation_compute_full_neumann_sfb ( cs_real_t  t_eval,
short int  def_id,
short int  f,
double *  neu_values
[in,out]neu_valuesarray storing Neumann values for all DoFs
◆ cs_equation_compute_full_neumann_svb()
void cs_equation_compute_full_neumann_svb ( cs_real_t  t_eval,
short int  def_id,
short int  f,
double *  neu_values
[in,out]neu_valuesarray storing the Neumann values for all DoFs
◆ cs_equation_compute_neumann_sfb()
void cs_equation_compute_neumann_sfb ( cs_real_t  t_eval,
short int  def_id,
short int  f,
double *  neu_values
◆ cs_equation_compute_neumann_svb()
void cs_equation_compute_neumann_svb ( cs_real_t  t_eval,
short int  def_id,
short int  f,
double *  neu_values
◆ cs_equation_compute_neumann_vfb()
void cs_equation_compute_neumann_vfb ( cs_real_t  t_eval,
short int  def_id,
short int  f,
double *  neu_values
[in,out]neu_valuesarray storing Neumann values at DoFs
