cs_enforcement.h File Reference
#include "cdo/cs_cdo_local.h"
+ Include dependency graph for cs_enforcement.h:
Classes
struct  cs_enforcement_param_t
 Set of data defining an enforcement. More...
Enumerations
enum  cs_enforcement_selection_t { CS_ENFORCEMENT_SELECTION_CELLS , CS_ENFORCEMENT_SELECTION_FACES , CS_ENFORCEMENT_SELECTION_EDGES , CS_ENFORCEMENT_SELECTION_VERTICES }
 Type of entities used to define the selection where the enforcement takes place. More...
enum  cs_enforcement_type_t { CS_ENFORCEMENT_BY_CONSTANT , CS_ENFORCEMENT_BY_DOF_VALUES }
 Describe the way the values to enforce are defined. More...
cs_enforcement_param_t * cs_enforcement_param_create (cs_enforcement_selection_t sel_type, cs_enforcement_type_t type, int stride, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *values)
 Create and define a cs_enforcement_param_t structure. More...
void cs_enforcement_param_reset (cs_enforcement_param_t *efp, cs_enforcement_selection_t sel_type, cs_enforcement_type_t type, int stride, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *values)
 Reset an existing cs_enforcement_param_t structure. More...
cs_enforcement_param_t * cs_enforcement_param_copy (const cs_enforcement_param_t *ref)
 Copy a cs_enforcement_param_t structure. More...
void cs_enforcement_param_free (cs_enforcement_param_t **p_efp)
 Free a cs_enforcement_param_t structure. More...
void cs_enforcement_param_log (const char *eqname, const cs_enforcement_param_t *efp)
 Log a cs_enforcement_param_t structure. More...
cs_real_t * cs_enforcement_define_at_vertices (const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
 Build a cs_enforcement_t structure for vertex-based scheme. More...
cs_real_t * cs_enforcement_define_at_faces (const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
 Build a cs_enforcement_t structure for face-based scheme. More...
cs_real_t * cs_enforcement_define_at_edges (const cs_cdo_connect_t *connect, int n_params, cs_enforcement_param_t **efp_array)
 Build a cs_enforcement_t structure for edge-based scheme. More...
bool cs_enforcement_dofs_cw (const cs_real_t *forced_values, cs_cell_sys_t *csys, cs_real_t *cw_forced_values)
 Build the cell-wise value to enforce. More...
◆ cs_enforcement_selection_t
Two mechanisms are possible.
1) Cell selection: defined a selection of cells and then automatically built the related selection of degrees of freedom and assigned a value to each selected degrees of freedom
2) DoF selection (faces or vertices up to now): defined a selection of degrees of freedom (DoFs) and assign a values to a selection of degrees of freedom inside
Enumerator
List of cell ids
List of face ids
List of edge ids
List of vertex ids
◆ cs_enforcement_type_t
Enumerator
The same constant value for each DoF
A prescribed value for each DoF
◆ cs_enforcement_define_at_edges()
cs_real_t * cs_enforcement_define_at_edges ( const cs_cdo_connect_t *  connect,
int  n_params,
cs_enforcement_param_t **  efp_array
[in]connectpointer to a cs_cdo_connect_t
[in]n_paramsnumber of enforcement parameters
[in]efp_arrayarray of parameter structures defining the enforcement
an array with the values to enforce
◆ cs_enforcement_define_at_faces()
cs_real_t * cs_enforcement_define_at_faces ( const cs_cdo_connect_t *  connect,
int  n_params,
◆ cs_enforcement_define_at_vertices()
cs_real_t * cs_enforcement_define_at_vertices ( const cs_cdo_connect_t *  connect,
int  n_params,
◆ cs_enforcement_dofs_cw()
bool cs_enforcement_dofs_cw ( const cs_real_t *  forced_values,
cs_cell_sys_t *  csys,
cs_real_t *  cw_forced_values
[in]forced_valuesvalues to enforce or FLT_MAX
[in,out]csyspointer to a cs_cell_sys_t structure
[in,out]cw_forced_valueslocal values to enforce
true if at least one DoF has to be enforced
◆ cs_enforcement_param_copy()
cs_enforcement_param_t * cs_enforcement_param_copy ( const cs_enforcement_param_t *  ref)
[in]refreference structure to copy
a pointer to a cs_enforcement_param_t structure
◆ cs_enforcement_param_create()
cs_enforcement_param_t * cs_enforcement_param_create ( cs_enforcement_selection_t  sel_type,
int  stride,
cs_lnum_t  n_elts,
const cs_lnum_t *  elt_ids,
const cs_real_t *  values
[in]sel_typetype of elements which have been selected
[in]typeway to set values for the selected elements
[in]stridenumber of values to enforce by element
[in]n_eltsnumber of selected elements locally
[in]elt_idslist of element ids
[in]valuesarray of values to enforce
◆ cs_enforcement_param_free()
void cs_enforcement_param_free ( cs_enforcement_param_t **  p_efp)
[in,out]p_efpdouble pointer to the structure to free
◆ cs_enforcement_param_log()
void cs_enforcement_param_log ( const char *  eqname,
const cs_enforcement_param_t *  efp
[in]efppointer to a cs_enforcement_param_t structure
◆ cs_enforcement_param_reset()
void cs_enforcement_param_reset ( cs_enforcement_param_t *  efp,
int  stride,
cs_lnum_t  n_elts,
[in,out]efppointer to a cs_enforcement_param_t structure
