cs_ctwr_source_terms.cpp File Reference
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "atmo/cs_air_props.h"
#include "base/cs_array.h"
#include "atmo/cs_atmo.h"
#include "ctwr/cs_ctwr_physical_properties.h"
#include "base/cs_field.h"
#include "lagr/cs_lagr.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_volume_mass_injection.h"
#include "base/cs_volume_zone.h"
#include "ctwr/cs_ctwr.h"
#include "ctwr/cs_ctwr_source_terms.h"
+ Include dependency graph for cs_ctwr_source_terms.cpp:
static cs_real_t _lewis_factor (const int evap_model, const cs_real_t molmassrat, const cs_real_t x, const cs_real_t x_s_tl)
static void _evap_packing (cs_ctwr_zone_t *ct, cs_real_t pref, cs_real_t t_h, cs_real_t t_l_p, cs_real_3_t vel_h, cs_real_t rho_h, cs_real_t ym_w, cs_real_t x, cs_real_t rho_l, cs_real_t y_l_p, cs_real_t vel_l, cs_real_t *beta_x_ai, cs_real_t *mass_source, cs_real_t *mass_source_oy)
static void _evap_rain (cs_air_fluid_props_t *air_prop, cs_real_t visc, cs_real_t pref, cs_real_t t_h, cs_real_t t_l_r, cs_real_3_t drift_vel_rain, cs_real_t x, cs_real_t x_s, cs_real_t rho_h, cs_real_t y_rain, cs_real_t rho_ref, cs_real_t rho_l, cs_real_t *beta_x_ai, cs_real_t *mass_source, cs_real_t *mass_source_oy)
void cs_ctwr_volume_mass_injection_packing_dof_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
 cs_dof_func_t function to compute volume mass injection for pressure (mass) equation resulting from water evaporation in the packing zones or rain injection. More...
void cs_ctwr_volume_mass_injection_evap_rain_dof_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
 cs_dof_func_t function to compute volume mass injection for pressure (mass) equation resulting from water evaporation of the rain. More...
void cs_ctwr_volume_mass_injection_rain_dof_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
 cs_dof_func_t function to compute volume mass injection for pressure (mass) equation for the leaking rain form packings if mixture model is on. More...
void cs_ctwr_volume_mass_injection_yh_rain_dof_func (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
 cs_dof_func_t function to compute volume mass injection for yphp rain equation (enthalpy) if mixture model is on. More...
void cs_ctwr_source_term (int f_id, cs_real_t exp_st[], cs_real_t imp_st[])
 Phase change source terms - Exchange terms between the injected liquid and the water vapor phase in the bulk, humid air. More...
◆ _evap_packing()
static void _evap_packing ( cs_ctwr_zone_t *  ct,
cs_real_t  pref,
cs_real_t  t_h,
cs_real_t  t_l_p,
cs_real_3_t  vel_h,
cs_real_t  rho_h,
cs_real_t  ym_w,
cs_real_t  x,
cs_real_t  rho_l,
cs_real_t  y_l_p,
cs_real_t  vel_l,
cs_real_t *  beta_x_ai,
cs_real_t *  mass_source,
cs_real_t *  mass_source_oy
static
◆ _evap_rain()
static void _evap_rain ( cs_air_fluid_props_t *  air_prop,
cs_real_t  visc,
cs_real_t  pref,
cs_real_t  t_h,
cs_real_t  t_l_r,
cs_real_t  x,
cs_real_t  x_s,
cs_real_t  rho_h,
cs_real_t  y_rain,
cs_real_t  rho_ref,
cs_real_t  rho_l,
static
◆ _lewis_factor()
static cs_real_t _lewis_factor ( const int  evap_model,
const cs_real_t  x,
static
◆ cs_ctwr_source_term()
void cs_ctwr_source_term ( int  f_id,
cs_real_t  exp_st[],
cs_real_t  imp_st[]
[in]f_idfield id
[in,out]exp_stExplicit source term
[in,out]imp_stImplicit source term
◆ cs_ctwr_volume_mass_injection_evap_rain_dof_func()
void cs_ctwr_volume_mass_injection_evap_rain_dof_func ( cs_lnum_t  n_elts,
const cs_lnum_t *  elt_ids,
bool  dense_output,
void *  input,
cs_real_t *  retval
cs_dof_func_t function to compute volume mass injection for pressure (mass) equation resulting from evaporation of the rain.
[in]n_eltsnumber of elements to consider
[in]elt_idslist of elements ids
[in]dense_outputperform an indirection in retval or not
[in]inputnull or pointer to a structure cast on-the-fly
[in,out]retvalresulting value(s). Must be allocated.
◆ cs_ctwr_volume_mass_injection_packing_dof_func()
void cs_ctwr_volume_mass_injection_packing_dof_func ( cs_lnum_t  n_elts,
bool  dense_output,
void *  input,
cs_real_t *  retval
cs_dof_func_t function to compute volume mass injection for pressure (mass) equation resulting from water evaporatin in the packing zones.
◆ cs_ctwr_volume_mass_injection_rain_dof_func()
void cs_ctwr_volume_mass_injection_rain_dof_func ( cs_lnum_t  n_elts,
bool  dense_output,
void *  input,
cs_real_t *  retval
cs_dof_func_t function to compute volume mass injection for pressure (mass) equation for the rain.
◆ cs_ctwr_volume_mass_injection_yh_rain_dof_func()
void cs_ctwr_volume_mass_injection_yh_rain_dof_func ( cs_lnum_t  n_elts,
bool  dense_output,
void *  input,
cs_real_t *  retval
cs_dof_func_t function to compute volume mass injection for yphp rain equation (enthalpy).
