cs_cf_thermo.cpp File Reference
#include "bft/bft_printf.h"
#include "base/cs_field.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parall.h"
#include "cfbl/cs_cf_model.h"
#include "cfbl/cs_hgn_thermo.h"
#include "cfbl/cs_cf_thermo.h"
+ Include dependency graph for cs_cf_thermo.cpp:
void cs_cf_set_thermo_options (void)
 Set variability of isobaric specific heat and isochoric specific heat according to the chosen thermodynamic law. More...
void cs_cf_thermo_default_init (void)
 Initialize density, total energy and isochoric specific heat according to the chosen thermodynamic law using the default parameters. More...
void cs_cf_check_pressure (cs_real_t *pres, cs_lnum_t n_elts)
 Check the positivity of the pressure. More...
void cs_cf_check_internal_energy (cs_real_t *ener, cs_lnum_t n_elts, cs_real_3_t *vel)
 Check the positivity of the internal energy. More...
void cs_cf_check_density (cs_real_t *rho, cs_lnum_t n_elts)
 Check the positivity of the density given by the user. More...
void cs_cf_check_temperature (cs_real_t *temp, cs_lnum_t n_elts)
 Check strict positivity of temperature (Celsius) given by the user. More...
void cs_cf_thermo_te_from_dp (cs_real_t *cp, cs_real_t *cv, cs_real_t *pres, cs_real_t *rho, cs_real_t *temp, cs_real_t *ener, cs_real_3_t *vel, cs_lnum_t n_elts)
 Compute temperature and total energy from density and pressure. More...
void cs_cf_thermo_de_from_pt (cs_real_t *cp, cs_real_t *cv, cs_real_t *pres, cs_real_t *temp, cs_real_t *rho, cs_real_t *ener, cs_real_3_t *vel, cs_lnum_t n_elts)
 Compute density and total energy from pressure and temperature. More...
void cs_cf_thermo_dt_from_pe (cs_real_t *cp, cs_real_t *cv, cs_real_t *pres, cs_real_t *ener, cs_real_t *rho, cs_real_t *temp, cs_real_3_t *vel, cs_lnum_t n_elts)
 Compute density and temperature from pressure and total energy;. More...
void cs_cf_thermo_pe_from_dt (cs_real_t *cp, cs_real_t *cv, cs_real_t *rho, cs_real_t *temp, cs_real_t *pres, cs_real_t *ener, cs_real_3_t *vel, cs_lnum_t n_elts)
 Compute pressure and total energy from density and temperature. More...
void cs_cf_thermo_pt_from_de (cs_real_t *cp, cs_real_t *cv, cs_real_t *rho, cs_real_t *ener, cs_real_t *pres, cs_real_t *temp, cs_real_3_t *vel, cs_real_t *fracv, cs_real_t *fracm, cs_real_t *frace, cs_lnum_t n_elts)
 Compute pressure and temperature from density and total energy. More...
void cs_cf_thermo_c_square (cs_real_t *cp, cs_real_t *cv, cs_real_t *pres, cs_real_t *rho, cs_real_t *fracv, cs_real_t *fracm, cs_real_t *frace, cs_real_t *c2, cs_lnum_t n_elts)
 Compute square of sound velocity: More...
void cs_cf_thermo_beta (cs_real_t *cp, cs_real_t *cv, cs_real_t *rho, cs_real_t *beta, cs_lnum_t n_elts)
 Compute the thermal expansion coefficient: More...
void cs_cf_thermo_cv (cs_real_t *cp, cs_real_t *xmasml, cs_real_t *cv, cs_lnum_t n_elts)
 Compute the isochoric specific heat: More...
void cs_cf_thermo_s_from_dp (cs_real_t *cp, cs_real_t *cv, cs_real_t *rho, cs_real_t *pres, cs_real_t *entr, cs_lnum_t n_elts)
 Compute entropy from pressure and density: More...
void cs_cf_thermo_wall_bc (cs_real_t *wbfa, cs_real_t *wbfb, cs_lnum_t face_id)
 Compute wall boundary condition values. More...
void cs_cf_thermo_subsonic_outlet_bc (cs_real_t *bc_en, cs_real_t *bc_pr, cs_real_3_t *bc_vel, cs_lnum_t face_id)
 Compute subsonic outlet boundary conditions values. More...
void cs_cf_thermo_ph_inlet_bc (cs_real_t *bc_en, cs_real_t *bc_pr, cs_real_3_t *bc_vel, cs_lnum_t face_id)
 Compute inlet boundary condition with total pressure and total enthalpy imposed. More...
void cs_cf_thermo_eps_sup (const cs_real_t *rho, cs_real_t *eps_sup, cs_lnum_t n_elts)
 Compute epsilon sup: More...
void cs_cf_thermo (const int iccfth, cs_lnum_t face_id, cs_real_t *bc_en, cs_real_t *bc_pr, cs_real_t *bc_tk, cs_real_3_t *bc_vel)
 This function is a driver allowing to call the appropriate thermodynamical functions depending on the quantities provided by the user. Hence it is only used during the initialization step and at the boundaries of type supersonic inlet. It is described in the following how to select the quantity to be returned. More...
cs_real_t cs_cf_thermo_b_rho_from_pt (cs_lnum_t face_id, cs_real_t bc_pr, cs_real_t bc_tk)
 Compute density at boundary based on pressure and temperature. More...
Define thermodynamic laws for the compressible flow module. Only the perfect gas law is available for now. The molar mass has to be provided either in the GUI or in cs_user_parameters.cpp.
◆ cs_cf_check_density()
void cs_cf_check_density ( cs_real_t *  rho,
cs_lnum_t  n_elts
[in]rhoarray of density values
[in]n_eltssize of the array
◆ cs_cf_check_internal_energy()
void cs_cf_check_internal_energy ( cs_real_t *  ener,
cs_lnum_t  n_elts,
cs_real_3_t *  vel
[in]enerarray of total energy values
[in]velarray of velocity values
◆ cs_cf_check_pressure()
void cs_cf_check_pressure ( cs_real_t *  pres,
cs_lnum_t  n_elts
[in]presarray of pressure values
◆ cs_cf_check_temperature()
void cs_cf_check_temperature ( cs_real_t *  temp,
cs_lnum_t  n_elts
[in]temparray of temperature values
◆ cs_cf_set_thermo_options()
void cs_cf_set_thermo_options ( void  )
◆ cs_cf_thermo()
void cs_cf_thermo ( const int  iccfth,
cs_lnum_t  face_id,
cs_real_t *  bc_en,
cs_real_t *  bc_pr,
cs_real_t *  bc_tk,
cs_real_3_t *  bc_vel
When calling the user subroutine, the integer 'iccfth' specifies which calculation has to be performed (and which quantity has to be returned). The values for 'iccfth' for each case are provided below.
The variables are referred to using a different index i:
  • pressure: 2
  • density: 3
  • temperature: 5
  • internal energy: 7
  • entropy: 13
iccfth is as follows, depending on which quantity needs to be computed:
  • variables at cell centers from variable i and variable j (i<j): iccfth = i*j*10000
  • variables at boundary faces from variable i and variable j (i<j): iccfth = i*j*10000+900
Detailed values of iccfth and corresponding computations:
Values at the cell centers:
  • temperature and energy from pressure and density: iccfth = 60000
  • density and energy from pressure and temperature: iccfth = 100000
  • density and temperature from pressure and energy: iccfth = 140000
  • pressure and energy from density and temperature: iccfth = 150000
  • pressure and temperature from density and energy: iccfth = 210000
Values at the faces for boundary conditions:
  • temperature and energy from pressure and density: iccfth = 60900
  • density and energy from pressure and temperature: iccfth = 100900
  • density and temperature from pressure and energy: iccfth = 140900
  • pressure and energy from density and temperature: iccfth = 150900
  • pressure and temperature from density and energy: iccfth = 210900
[in]iccfthid of computation
[in]face_idface index if the computation is for a B.C. -1 if the computation is located on cells
[in,out]bc_entotal energy values at boundary faces
[in,out]bc_prpressure values at boundary faces
[in,out]bc_tktemperature values at boundary faces
[in,out]bc_velvelocity values at boundary faces
◆ cs_cf_thermo_b_rho_from_pt()
cs_real_t cs_cf_thermo_b_rho_from_pt ( cs_lnum_t  face_id,
cs_real_t  bc_pr,
cs_real_t  bc_tk
This is needed when imposing a mass flow rate on a given inlet.
[in]face_idface id
[in]bc_prpressure value at boundary face
[in]bc_tktemperature value at boundary face
density at boundary face
◆ cs_cf_thermo_beta()
void cs_cf_thermo_beta ( cs_real_t *  cp,
cs_real_t *  cv,
cs_real_t *  rho,
cs_real_t *  beta,
cs_lnum_t  n_elts
\[ \beta = \left(\frac{\partial p}{\partial s}\right)_\rho \]
for a perfect gas, the explicit formula is:
\[ \beta = \rho^\gamma \]
[in]cparray of isobaric specific heat values
[in]cvarray of isochoric specific heat values
[out]betaarray of beta values
◆ cs_cf_thermo_c_square()
void cs_cf_thermo_c_square ( cs_real_t *  cp,
cs_real_t *  cv,
cs_real_t *  pres,
cs_real_t *  rho,
cs_real_t *  fracv,
cs_real_t *  fracm,
cs_real_t *  frace,
cs_real_t *  c2,
cs_lnum_t  n_elts
\[c^2  = \left(\frac{\partial p}{\partial \rho}\right)_s\]
for perfect gas, this expression simply writes:
\[c^2  = \gamma \frac{p}{\rho}\]
[in,out]fracvarray of volume fraction values
[in,out]fracmarray of mass fraction values
[in,out]fracearray of energy fraction values
[out]c2array of the values of the square of sound velocity
◆ cs_cf_thermo_cv()
void cs_cf_thermo_cv ( cs_real_t *  cp,
cs_real_t *  xmasml,
cs_real_t *  cv,
cs_lnum_t  n_elts
\[C_v = \left(\frac{\partial e}{\partial T}\right)_\rho\]
[in]xmasmlarray of molar mass values
[out]cvarray of isochoric specific heat values
◆ cs_cf_thermo_de_from_pt()
void cs_cf_thermo_de_from_pt ( cs_real_t *  cp,
cs_real_t *  cv,
cs_real_t *  pres,
cs_real_t *  temp,
cs_real_t *  rho,
cs_real_t *  ener,
cs_real_3_t *  vel,
cs_lnum_t  n_elts
[out]rhoarray of density values
[out]enerarray of total energy values
[in]velarray of velocity component values
◆ cs_cf_thermo_default_init()
void cs_cf_thermo_default_init ( void  )
◆ cs_cf_thermo_dt_from_pe()
void cs_cf_thermo_dt_from_pe ( cs_real_t *  cp,
cs_real_t *  cv,
cs_real_t *  pres,
cs_real_t *  ener,
cs_real_t *  rho,
cs_real_t *  temp,
cs_real_3_t *  vel,
cs_lnum_t  n_elts
[out]temparray of temperature values
◆ cs_cf_thermo_eps_sup()
void cs_cf_thermo_eps_sup ( const cs_real_t *  rho,
cs_real_t *  eps_sup,
cs_lnum_t  n_elts
\[\epsilon_{\textrm{sup}} = e - C_v T\]
for perfect gas:
\[\epsilon_{\textrm{sup}} = 0\]
[out]eps_supepsilon sup array
◆ cs_cf_thermo_pe_from_dt()
void cs_cf_thermo_pe_from_dt ( cs_real_t *  cp,
cs_real_t *  cv,
cs_real_t *  rho,
cs_real_t *  temp,
cs_real_t *  pres,
cs_real_t *  ener,
cs_real_3_t *  vel,
cs_lnum_t  n_elts
[out]presarray of pressure values
◆ cs_cf_thermo_ph_inlet_bc()
void cs_cf_thermo_ph_inlet_bc ( cs_real_t *  bc_en,
cs_real_t *  bc_pr,
cs_real_3_t *  bc_vel,
cs_lnum_t  face_id
[in]face_idboundary face index
◆ cs_cf_thermo_pt_from_de()
void cs_cf_thermo_pt_from_de ( cs_real_t *  cp,
cs_real_t *  cv,
cs_real_t *  rho,
cs_real_t *  ener,
cs_real_t *  pres,
cs_real_t *  temp,
cs_real_3_t *  vel,
cs_real_t *  fracv,
cs_real_t *  fracm,
cs_real_t *  frace,
cs_lnum_t  n_elts
◆ cs_cf_thermo_s_from_dp()
void cs_cf_thermo_s_from_dp ( cs_real_t *  cp,
cs_real_t *  cv,
cs_real_t *  rho,
cs_real_t *  pres,
cs_real_t *  entr,
cs_lnum_t  n_elts
\[s = \frac{p}{\rho^\gamma}\]
[out]entrarray of total energy values
◆ cs_cf_thermo_subsonic_outlet_bc()
void cs_cf_thermo_subsonic_outlet_bc ( cs_real_t *  bc_en,
cs_real_t *  bc_pr,
cs_lnum_t  face_id
◆ cs_cf_thermo_te_from_dp()
void cs_cf_thermo_te_from_dp ( cs_real_t *  cp,
cs_real_t *  cv,
cs_real_t *  pres,
cs_real_t *  rho,
cs_real_t *  temp,
cs_real_t *  ener,
cs_real_3_t *  vel,
cs_lnum_t  n_elts
◆ cs_cf_thermo_wall_bc()
void cs_cf_thermo_wall_bc ( cs_real_t *  wbfa,
cs_real_t *  wbfb,
cs_lnum_t  face_id
[in,out]wbfaoutput work array
[in,out]wbfboutput work array
