cs_cf_model.h File Reference
+ Include dependency graph for cs_cf_model.h:
Classes
struct  cs_cf_model_t
 Compressible model general options descriptor. More...
Enumerations
enum  cs_cf_model_eos_t {
  CS_EOS_NONE = -1 , CS_EOS_IDEAL_GAS = 1 , CS_EOS_STIFFENED_GAS = 2 , CS_EOS_GAS_MIX = 3 ,
  CS_EOS_HOMOGENEOUS_TWO_PHASE = 4 , CS_EOS_MOIST_AIR = 5
cs_cf_model_t * cs_get_glob_cf_model (void)
 Provide access to compressible model global structure cs_glob_cf_model. More...
void cs_cf_add_variable_fields (void)
 Variable field definitions for the compressible module, according to calculation type selected by the user. More...
void cs_cf_add_property_fields (void)
 Property field definitions for the compressible module, according to calculation type selected by the user. More...
void cs_cf_setup (void)
 Setup options specific to the compressible model. More...
void cs_cf_model_log_setup (void)
 Print the compressible module options to setup.log. More...
void cs_cf_initialize (void)
 Initialize variables of the compressible flow model. More...
void cs_cf_physical_properties (void)
 Compute variable physical properties for the compressible module. More...
const cs_cf_model_t * cs_glob_cf_model
◆ cs_cf_model_eos_t
Enumerator
CS_EOS_NONE
CS_EOS_IDEAL_GAS
CS_EOS_GAS_MIX
CS_EOS_MOIST_AIR
◆ cs_cf_add_property_fields()
void cs_cf_add_property_fields ( void  )
◆ cs_cf_add_variable_fields()
void cs_cf_add_variable_fields ( void  )
◆ cs_cf_initialize()
void cs_cf_initialize ( void  )
◆ cs_cf_model_log_setup()
void cs_cf_model_log_setup ( void  )
◆ cs_cf_physical_properties()
void cs_cf_physical_properties ( void  )
◆ cs_cf_setup()
void cs_cf_setup ( void  )
◆ cs_get_glob_cf_model()
cs_cf_model_t * cs_get_glob_cf_model ( void  )
◆ cs_glob_cf_model
const cs_cf_model_t* cs_glob_cf_model
extern
