cs_cf_model.cpp File Reference
#include "bft/bft_error.h"
#include "base/cs_array.h"
#include "base/cs_field.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parameters_check.h"
#include "base/cs_physical_properties.h"
#include "base/cs_restart_default.h"
#include "base/cs_velocity_pressure.h"
#include "cfbl/cs_cf_model.h"
#include "cfbl/cs_cf_thermo.h"
+ Include dependency graph for cs_cf_model.cpp:
cs_cf_model_t * cs_get_glob_cf_model (void)
 Provide access to compressible model global structure cs_glob_cf_model. More...
void cs_cf_add_variable_fields (void)
 Variable field definitions for the compressible module, according to calculation type selected by the user. More...
void cs_cf_add_property_fields (void)
 Property field definitions for the compressible module, according to calculation type selected by the user. More...
void cs_cf_setup (void)
 Setup options specific to the compressible model. More...
void cs_cf_model_log_setup (void)
 Print the compressible module options to setup.log. More...
void cs_cf_initialize (void)
 Initialize variables of the compressible flow model. More...
void cs_cf_physical_properties (void)
 Compute variable physical properties for the compressible module. More...
Compressible models data.
◆ cs_cf_add_property_fields()
void cs_cf_add_property_fields ( void  )
◆ cs_cf_add_variable_fields()
void cs_cf_add_variable_fields ( void  )
◆ cs_cf_initialize()
void cs_cf_initialize ( void  )
◆ cs_cf_model_log_setup()
void cs_cf_model_log_setup ( void  )
◆ cs_cf_physical_properties()
void cs_cf_physical_properties ( void  )
◆ cs_cf_setup()
void cs_cf_setup ( void  )
◆ cs_get_glob_cf_model()
cs_cf_model_t * cs_get_glob_cf_model ( void  )
