cs_cdovcb_scaleq.cpp File Reference
Build an algebraic CDO vertex+cell-based system for unsteady convection diffusion reaction of scalar-valued equations with source terms. More...
#include "base/cs_mem.h"
#include "base/cs_array.h"
#include "cdo/cs_cdo_advection.h"
#include "cdo/cs_cdo_assembly.h"
#include "cdo/cs_cdo_bc.h"
#include "cdo/cs_cdo_diffusion.h"
#include "cdo/cs_cdo_local.h"
#include "cdo/cs_cdo_solve.h"
#include "cdo/cs_cdo_system.h"
#include "cdo/cs_cdo_toolbox.h"
#include "cdo/cs_equation_builder.h"
#include "cdo/cs_evaluate.h"
#include "cdo/cs_hodge.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_post.h"
#include "cdo/cs_reco.h"
#include "cdo/cs_reco_cw.h"
#include "cdo/cs_scheme_geometry.h"
#include "alge/cs_sles.h"
#include "cdo/cs_static_condensation.h"
#include "base/cs_timer.h"
#include "cdo/cs_cdovcb_scaleq.h"
+ Include dependency graph for cs_cdovcb_scaleq.cpp:
bool cs_cdovcb_scaleq_is_initialized (void)
 Check if the generic structures for building a CDO-vertex+cell based scheme are allocated. More...
void cs_cdovcb_scaleq_init_sharing (const cs_cdo_quantities_t *cdoq, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
 Allocate work buffer and general structures related to CDO vertex+cell-based schemes Set shared pointers. More...
void cs_cdovcb_scaleq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb)
void cs_cdovcb_scaleq_finalize_sharing (void)
 Free work buffer and general structure related to CDO vertex-based schemes. More...
void * cs_cdovcb_scaleq_init_context (cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
 Initialize a cs_cdovcb_scaleq_t structure storing data useful for building and managing such a scheme. More...
void * cs_cdovcb_scaleq_free_context (void *data)
 Destroy a cs_cdovcb_scaleq_t structure. More...
void cs_cdovcb_scaleq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Set the initial values of the variable field taking into account the boundary conditions. Case of scalar-valued CDO-VCb schemes. More...
void cs_cdovcb_scaleq_interpolate (const cs_mesh_t *mesh, const cs_real_t *cell_values, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Build and solve the linear system arising from a scalar steady-state equation with a CDO-VCb scheme. Use for interpolation purpose from cell values to vertex values. One works cellwise and then process to the assembly. More...
void cs_cdovcb_scaleq_solve_steady_state (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Build and solve the linear system arising from a scalar steady-state convection/diffusion/reaction equation with a CDO-VCb scheme One works cellwise and then process to the assembly. More...
void cs_cdovcb_scaleq_solve_implicit (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Build and solve the linear system arising from a scalar unsteady convection/diffusion/reaction equation with a CDO-VCb scheme Time scheme is an implicit Euler One works cellwise and then process to the assembly. More...
void cs_cdovcb_scaleq_solve_theta (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Build and solve the linear system arising from a scalar unsteady convection/diffusion/reaction equation with a CDO-VCb scheme Time scheme is a theta scheme. One works cellwise and then process to the assembly. More...
cs_real_t * cs_cdovcb_scaleq_get_vertex_values (void *context, bool previous)
 Retrieve an array of values at mesh vertices for the variable field associated to the given context The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More...
cs_real_t * cs_cdovcb_scaleq_get_cell_values (void *context, bool previous)
 Get the computed values at mesh cells from the inverse operation w.r.t. the static condensation (DoF used in the linear system are located at primal vertices and field related to the structure equation is also attached to primal vertices) The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More...
cs_real_t * cs_cdovcb_scaleq_get_source_term_values (void *context)
 Retrieve the array storing the source term values associated to each DoF. The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More...
void cs_cdovcb_scaleq_boundary_diff_flux (const cs_real_t *pot_v, const cs_real_t *pot_c, const cs_equation_param_t *eqp, const cs_property_t *diff_pty, const cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *vf_flux)
 Compute for each vertex of a boundary face, the portion of diffusive flux across the boundary face. The surface attached to each vertex corresponds to the intersection of its dual cell (associated to a vertex of the face) with the face. Case of scalar-valued CDO-VCb schemes. More...
void cs_cdovcb_scaleq_flux_across_plane (const cs_real_t normal[], const cs_real_t *pdi, const cs_equation_param_t *eqp, int ml_id, cs_equation_builder_t *eqb, void *context, double *d_flux, double *c_flux)
 Compute the diffusive and convective flux across a list of faces Case of scalar-valued CDO-VCb schemes. More...
void cs_cdovcb_scaleq_diff_flux_in_cells (const cs_real_t *v_values, const cs_real_t *c_values, const cs_equation_param_t *eqp, const cs_property_t *diff_pty, cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *diff_flux)
 Cellwise and threaed computation of the diffusive flux in each cells. Case of scalar-valued CDO-VCb schemes. More...
void cs_cdovcb_scaleq_diff_flux_dfaces (const cs_real_t *v_values, const cs_real_t *c_values, const cs_equation_param_t *eqp, const cs_property_t *diff_pty, cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *diff_flux)
 Cellwise and threaded computation of the diffusive flux across dual faces. This is only an interpolation since the dual faces are not the natural location for this discretization. Case of scalar-valued CDO-VCb schemes. More...
void cs_cdovcb_scaleq_vtx_gradient (const cs_real_t *v_values, cs_equation_builder_t *eqb, void *context, cs_real_t *v_gradient)
 Cellwise computation of the discrete gradient at vertices. More...
void cs_cdovcb_scaleq_read_restart (cs_restart_t *restart, const char *eqname, void *scheme_context)
void cs_cdovcb_scaleq_write_restart (cs_restart_t *restart, const char *eqname, void *scheme_context)
void cs_cdovcb_scaleq_current_to_previous (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
void cs_cdovcb_scaleq_extra_post (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
static cs_cell_sys_t ** _vcbs_cell_system = nullptr
static cs_cell_builder_t ** _vcbs_cell_builder = nullptr
static const cs_cdo_quantities_t * cs_shared_quant
static const cs_cdo_connect_t * cs_shared_connect
static const cs_time_step_t * cs_shared_time_step
◆ cs_cdovcb_scaleq_boundary_diff_flux()
void cs_cdovcb_scaleq_boundary_diff_flux ( const cs_real_t *  pot_v,
const cs_real_t *  pot_c,
const cs_property_t *  diff_pty,
cs_equation_builder_t *  eqb,
void *  context,
cs_real_t *  vf_flux
[in]pot_vvalues at the location of the degrees of freedom
[in]pot_cvalues at the cell centers or nullptr
[in]diff_ptydiffusion property or nullptr
[in,out]contextpointer to a scheme builder structure
[in,out]vf_fluxpointer to the values of the diffusive flux
◆ cs_cdovcb_scaleq_current_to_previous()
void cs_cdovcb_scaleq_current_to_previous ( const cs_equation_param_t *  eqp,
void *  context
[in,out]contextpointer to cs_cdovcb_scaleq_t structure
◆ cs_cdovcb_scaleq_diff_flux_dfaces()
void cs_cdovcb_scaleq_diff_flux_dfaces ( const cs_real_t *  v_values,
const cs_real_t *  c_values,
cs_real_t  t_eval,
void *  context,
cs_real_t *  diff_flux
[in]v_valuesvalues at vertices
[in]c_valuesvalues at cells
[in]diff_ptypointer to the diffusion property to use
[in,out]contextpointer to data structure cast on-the-fly
[in,out]diff_fluxvalue of the diffusive flux
◆ cs_cdovcb_scaleq_diff_flux_in_cells()
void cs_cdovcb_scaleq_diff_flux_in_cells ( const cs_real_t *  v_values,
cs_real_t  t_eval,
void *  context,
◆ cs_cdovcb_scaleq_extra_post()
void cs_cdovcb_scaleq_extra_post ( const cs_equation_param_t *  eqp,
void *  context
◆ cs_cdovcb_scaleq_finalize_sharing()
void cs_cdovcb_scaleq_finalize_sharing ( void  )
Free buffers and generic structures related to CDO vertex+cell-based schemes.
◆ cs_cdovcb_scaleq_flux_across_plane()
void cs_cdovcb_scaleq_flux_across_plane ( const cs_real_t  normal[],
const cs_real_t *  pdi,
int  ml_id,
void *  context,
double *  d_flux,
double *  c_flux
Compute the diffusive and convective flux across a list of faces Case of scalar-valued CDO-Vcb schemes.
[in]normalindicate in which direction flux is > 0
[in]pdipointer to an array of field values
[in]ml_idid related to a cs_mesh_location_t struct.
[in,out]contextpointer to data specific for this scheme
[in,out]d_fluxpointer to the value of the diffusive flux
[in,out]c_fluxpointer to the value of the convective flux
◆ cs_cdovcb_scaleq_free_context()
void * cs_cdovcb_scaleq_free_context ( void *  data)
[in,out]datapointer to a cs_cdovcb_scaleq_t structure
a null pointer
◆ cs_cdovcb_scaleq_get()
void cs_cdovcb_scaleq_get ( cs_cell_sys_t **  csys,
cs_cell_builder_t **  cb
◆ cs_cdovcb_scaleq_get_cell_values()
cs_real_t * cs_cdovcb_scaleq_get_cell_values ( void *  context,
bool  previous
a pointer to an array of cs_real_t (size: n_cells)
◆ cs_cdovcb_scaleq_get_source_term_values()
cs_real_t * cs_cdovcb_scaleq_get_source_term_values ( void *  context)
a pointer to an array of cs_real_t (size n_vertices + n_cells)
◆ cs_cdovcb_scaleq_get_vertex_values()
cs_real_t * cs_cdovcb_scaleq_get_vertex_values ( void *  context,
bool  previous
a pointer to an array of cs_real_t (size: n_vertices)
◆ cs_cdovcb_scaleq_init_context()
void * cs_cdovcb_scaleq_init_context ( cs_equation_param_t *  eqp,
int  var_id,
int  bflux_id,
a pointer to a new allocated cs_cdovcb_scaleq_t structure
◆ cs_cdovcb_scaleq_init_sharing()
void cs_cdovcb_scaleq_init_sharing ( const cs_cdo_quantities_t *  cdoq,
[in]cdoqadditional CDO mesh quantities
◆ cs_cdovcb_scaleq_init_values()
void cs_cdovcb_scaleq_init_values ( cs_real_t  t_eval,
const int  field_id,
const cs_mesh_t *  mesh,
void *  context
◆ cs_cdovcb_scaleq_interpolate()
void cs_cdovcb_scaleq_interpolate ( const cs_mesh_t *  mesh,
const cs_real_t *  cell_values,
const int  field_id,
void *  context
[in]cell_valuesarray of cell values
[in]field_idid of the variable field
◆ cs_cdovcb_scaleq_is_initialized()
bool cs_cdovcb_scaleq_is_initialized ( void  )
true or false
◆ cs_cdovcb_scaleq_read_restart()
void cs_cdovcb_scaleq_read_restart ( cs_restart_t *  restart,
const char *  eqname,
void *  scheme_context
◆ cs_cdovcb_scaleq_solve_implicit()
void cs_cdovcb_scaleq_solve_implicit ( bool  cur2prev,
const int  field_id,
void *  context
◆ cs_cdovcb_scaleq_solve_steady_state()
void cs_cdovcb_scaleq_solve_steady_state ( bool  cur2prev,
const int  field_id,
void *  context
◆ cs_cdovcb_scaleq_solve_theta()
void cs_cdovcb_scaleq_solve_theta ( bool  cur2prev,
const int  field_id,
void *  context
◆ cs_cdovcb_scaleq_vtx_gradient()
void cs_cdovcb_scaleq_vtx_gradient ( const cs_real_t *  v_values,
void *  context,
cs_real_t *  v_gradient
[in]v_valuesdiscrete values for the potential at vertices
[in,out]v_gradientgradient at vertices
◆ cs_cdovcb_scaleq_write_restart()
void cs_cdovcb_scaleq_write_restart ( cs_restart_t *  restart,
◆ _vcbs_cell_builder
cs_cell_builder_t** _vcbs_cell_builder = nullptr
static
◆ _vcbs_cell_system
cs_cell_sys_t** _vcbs_cell_system = nullptr
static
◆ cs_shared_connect
const cs_cdo_connect_t* cs_shared_connect
static
◆ cs_shared_quant
const cs_cdo_quantities_t* cs_shared_quant
static
◆ cs_shared_time_step
const cs_time_step_t* cs_shared_time_step
static
