cs_cdocb_scaleq.h File Reference
#include "base/cs_base.h"
#include "cdo/cs_cdocb_priv.h"
#include "cdo/cs_cdo_quantities.h"
#include "cdo/cs_equation.h"
#include "mesh/cs_mesh.h"
#include "cdo/cs_domain.h"
+ Include dependency graph for cs_cdocb_scaleq.h:
bool cs_cdocb_scaleq_is_initialized (void)
 Check if the generic structures for building a CDO-Cb scheme are allocated. More...
void cs_cdocb_scaleq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb)
void cs_cdocb_scaleq_init_sharing (const cs_mesh_t *mesh, const cs_cdo_quantities_t *cdoq, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
void cs_cdocb_scaleq_finalize_sharing (void)
 Free shared pointers with lifecycle dedicated to this file. More...
void * cs_cdocb_scaleq_init_context (cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
 Initialize a cs_cdocb_scaleq_t structure storing data useful for building and managing such a scheme. More...
void * cs_cdocb_scaleq_free_context (void *scheme_context)
 Destroy a cs_cdocb_scaleq_t structure. More...
void cs_cdocb_scaleq_setup (cs_real_t t_eval, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb)
 Set the boundary conditions known from the settings Define an indirection array for the enforcement of internal DoFs only if needed. Case of scalar-valued CDO-Cb schemes. More...
void cs_cdocb_scaleq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Set the initial values of the variable field taking into account the boundary conditions. Case of scalar-valued CDO-Cb schemes. More...
void cs_cdocb_scaleq_diffusion (const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_cdocb_scaleq_t *eqc, const cs_cell_mesh_t *cm, cs_hodge_t *diff_hodge, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Build the local matrices arising from the diffusion term in the scalar-valued CDO-Cb schemes. More...
void cs_cdocb_scaleq_solve_steady_state (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Solve the steady-state equation with a CDO cell-based scheme Scalar-valued diffusion equation up-to-now One works cellwise and then process to the assembly. More...
void cs_cdocb_scaleq_current_to_previous (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Copy current content of the related variables-fields to previous values Case of the monolithic coupling algorithm. More...
cs_real_t * cs_cdocb_scaleq_get_cell_values (void *context, bool previous)
 Retrieve an array of values at mesh cellss for the variable field associated to the given context The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More...
cs_real_t * cs_cdocb_scaleq_get_face_values (void *context, bool previous)
 Retrieve an array of values at mesh faces for the variable field associated to the given context The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More...
void cs_cdocb_scaleq_diff_flux_faces (const cs_real_t *values, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *diff_flux)
 Cellwise computation of the diffusive flux accross (primal) faces A scalar-valued flux for each face. Case of scalar-valued CDO-Cb schemes. More...
cs_cdo_balance_t * cs_cdocb_scaleq_balance (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Compute the balance for an equation over the full computational domain Case of scalar-valued CDO cell-based scheme. More...
void cs_cdocb_scaleq_extra_post (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
◆ cs_cdocb_scaleq_balance()
cs_cdo_balance_t * cs_cdocb_scaleq_balance ( const cs_equation_param_t *  eqp,
cs_equation_builder_t *  eqb,
void *  context
[in,out]contextpointer to a scheme builder structure
a pointer to a cs_cdo_balance_t structure
◆ cs_cdocb_scaleq_current_to_previous()
void cs_cdocb_scaleq_current_to_previous ( const cs_equation_param_t *  eqp,
void *  context
[in,out]contextpointer to a scheme context structure
◆ cs_cdocb_scaleq_diff_flux_faces()
void cs_cdocb_scaleq_diff_flux_faces ( const cs_real_t *  values,
cs_real_t  t_eval,
void *  context,
cs_real_t *  diff_flux
[in]valuesdiscrete values for the potential
[in,out]contextpointer to cs_cdovb_scaleq_t structure
[in,out]diff_fluxvalues of the diffusive flux
◆ cs_cdocb_scaleq_diffusion()
void cs_cdocb_scaleq_diffusion ( const cs_equation_param_t *  eqp,
const cs_equation_builder_t *  eqb,
const cs_cdocb_scaleq_t *  eqc,
const cs_cell_mesh_t *  cm,
cs_hodge_t *  diff_hodge,
cs_cell_sys_t *  csys,
cs_cell_builder_t *  cb
[in]eqbpointer to a cs_equation_builder_t structure
[in]eqccontext for this kind of discretization
[in]cmpointer to a cellwise view of the mesh
[in,out]diff_hodgepointer to a cs_hodge_t structure for diffusion
◆ cs_cdocb_scaleq_extra_post()
void cs_cdocb_scaleq_extra_post ( const cs_equation_param_t *  eqp,
void *  context
[in,out]contextpointer to cs_cdocb_scaleq_t structure
◆ cs_cdocb_scaleq_finalize_sharing()
void cs_cdocb_scaleq_finalize_sharing ( void  )
◆ cs_cdocb_scaleq_free_context()
void * cs_cdocb_scaleq_free_context ( void *  scheme_context)
[in,out]scheme_contextpointer to a scheme context to free
a null pointer
◆ cs_cdocb_scaleq_get()
void cs_cdocb_scaleq_get ( cs_cell_sys_t **  csys,
cs_cell_builder_t **  cb
◆ cs_cdocb_scaleq_get_cell_values()
cs_real_t * cs_cdocb_scaleq_get_cell_values ( void *  context,
bool  previous
a pointer to an array of cs_real_t (size: n_cells)
◆ cs_cdocb_scaleq_get_face_values()
cs_real_t * cs_cdocb_scaleq_get_face_values ( void *  context,
bool  previous
a pointer to an array of cs_real_t (size: n_faces)
◆ cs_cdocb_scaleq_init_context()
void * cs_cdocb_scaleq_init_context ( cs_equation_param_t *  eqp,
int  var_id,
int  bflux_id,
[in,out]eqbpointer to a cs_equation_builder_t struct.
a pointer to a new allocated cs_cdocb_scaleq_t structure
◆ cs_cdocb_scaleq_init_sharing()
void cs_cdocb_scaleq_init_sharing ( const cs_mesh_t *  mesh,
const cs_cdo_quantities_t *  cdoq,
[in]meshpointer to the mesh structure
[in]cdoqadditional CDO mesh quantities
◆ cs_cdocb_scaleq_init_values()
void cs_cdocb_scaleq_init_values ( cs_real_t  t_eval,
const int  field_id,
void *  context
◆ cs_cdocb_scaleq_is_initialized()
bool cs_cdocb_scaleq_is_initialized ( void  )
true or false
◆ cs_cdocb_scaleq_setup()
void cs_cdocb_scaleq_setup ( cs_real_t  t_eval,
◆ cs_cdocb_scaleq_solve_steady_state()
void cs_cdocb_scaleq_solve_steady_state ( bool  cur2prev,
const int  field_id,
void *  context
