cs_cdo_turbulence.h File Reference
+ Include dependency graph for cs_cdo_turbulence.h:
Classes
struct  cs_turbulence_param_t
 Structure storing the parameters related to the resolution of the turbulence modelling. Several members are structures defined in cs_turbulence_model.h as a global variable. The purpose of this structure is to store all parameters in one place. More...
struct  cs_turbulence_t
Macros
#define CS_NAVSTO_TOTAL_VISCOSITY   "total_viscosity"
#define CS_NAVSTO_LAM_VISCOSITY   "laminar_viscosity"
#define CS_NAVSTO_TURB_VISCOSITY   "turbulent_viscosity"
Typedefs
typedef void *() cs_turb_init_context_t(const cs_turb_model_t *tbm)
 Allocate and initialize the context structure related to a given turbulence modelling. More...
typedef void *() cs_turb_free_context_t(void *turb_context)
 Free the context structure related to a given turbulence modelling. More...
typedef void() cs_turb_compute_t(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs)
 Compute for the current time step the new state for the turbulence model. This means that all related equations are built and then solved. More...
typedef void() cs_turb_update_t(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, const cs_turbulence_t *tbs)
 Update properties, arrays related to the turbulent variables. More...
cs_turbulence_param_t * cs_turbulence_param_create (void)
 Allocate the structure storing the set of parameters for the turbulence modelling. More...
cs_turbulence_t * cs_turbulence_create (cs_turbulence_param_t *tbp)
 Allocate the structure managing the turbulence modelling. More...
void cs_turbulence_free (cs_turbulence_t **p_turb_struct)
 Free the structure managing the turbulence modelling. More...
void cs_turbulence_init_setup (cs_turbulence_t *tbs, cs_equation_t *mom_eq)
 Initialize the structure managing the turbulence modelling. More...
void cs_turbulence_finalize_setup (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs)
 Finalize the setup of the turbulence modelling and especially the equations/properties and other related quantities. More...
void cs_turbulence_set_shared_from_fv (cs_turbulence_t *tbs, bool is_shared)
 Indicate whether use Legacy solved turbulent viscosity. More...
void cs_turbulence_init_values (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs)
 Initialize the values of quantities related to a turbulence model. More...
void * cs_turb_init_k_eps_context (const cs_turb_model_t *tbm)
 Allocate and initialize the context structure related to the k-epsilon turbulence model. More...
void * cs_turb_free_k_eps_context (void *tbc)
 Free the context structure related to the k-epsilon turbulence model. More...
void cs_turb_compute_k_eps (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, cs_turbulence_t *tbs)
void cs_turb_update_k_eps (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, const cs_turbulence_t *tbs)
 Update for the current time step the new state for the turbulence model. This is used to update the turbulent viscosity. More...
void cs_turb_update_shared_legacy (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, const cs_turbulence_t *tbs)
 Update for the current time step the new state for the turbulence model. directly update the turbulent viscosity from Legacy. More...
void cs_turb_compute_wall_bc_coeffs (const cs_equation_param_t *eqp, const double nu, const double k, const double hfc, const double uct, cs_real_t *res)
 Function used to define the exchange coefficients for tangential and normal components. More...
bool cs_turb_wall_functions_is_activated (const cs_turbulence_param_t *turbulence)
 Return true if a wall function is used for turbulence. More...
◆ CS_NAVSTO_LAM_VISCOSITY
◆ CS_NAVSTO_TOTAL_VISCOSITY
◆ CS_NAVSTO_TURB_VISCOSITY
Typedef Documentation
◆ cs_turb_compute_t
[in]time_stepstructure managing the time stepping
[in,out]tbspointer to turbulence structure
◆ cs_turb_free_context_t
[in,out]tbcpointer to a structure cast on-the-fly to free
a null pointer
◆ cs_turb_init_context_t
[in]tbmpointer to a cs_turb_model_t structure
a pointer to a new allocated turbulence context structure
◆ cs_turb_update_t
[in]tbspointer to a cs_turbulence_t structure
◆ cs_turb_compute_k_eps()
void cs_turb_compute_k_eps ( const cs_mesh_t *  mesh,
const cs_time_step_t *  time_step,
cs_turbulence_t *  tbs
◆ cs_turb_compute_wall_bc_coeffs()
void cs_turb_compute_wall_bc_coeffs ( const cs_equation_param_t *  eqp,
const double  nu,
const double  k,
const double  hfc,
const double  uct,
cs_real_t *  res
[in]eqppointer to a cs_equation_param_t
[in]nulaminar kinematic viscosity
[in]kturbulent kinetic energy
[in]hfcdistance from cell center to the wall
[in]uctnorm of tangential components of cell velocity
[in,out]retvalexchange coefficients result
◆ cs_turb_free_k_eps_context()
void * cs_turb_free_k_eps_context ( void *  tbc)
[in,out]tbcpointer to a structure context cast on-the-fly
a null pointer
◆ cs_turb_init_k_eps_context()
void * cs_turb_init_k_eps_context ( const cs_turb_model_t *  tbm)
[in]tbmstructure which defines the turbulence model
a pointer to a new allocated context structure
◆ cs_turb_update_k_eps()
void cs_turb_update_k_eps ( const cs_mesh_t *  mesh,
const cs_turbulence_t *  tbs
◆ cs_turb_update_shared_legacy()
void cs_turb_update_shared_legacy ( const cs_mesh_t *  mesh,
◆ cs_turb_wall_functions_is_activated()
bool cs_turb_wall_functions_is_activated ( const cs_turbulence_param_t *  turbulence)
[in]turbulencepointer to a cs_turbulence_param_t
[out]retvaluse or nor a wall function
◆ cs_turbulence_create()
cs_turbulence_t * cs_turbulence_create ( cs_turbulence_param_t *  tbp)
[in]tbppointer to a cs_turbulence_param_t structure
a pointer to a new allocated cs_turbulence_t structure
◆ cs_turbulence_finalize_setup()
void cs_turbulence_finalize_setup ( const cs_mesh_t *  mesh,
[in,out]tbspointer to the turbulence main structure
◆ cs_turbulence_free()
void cs_turbulence_free ( cs_turbulence_t **  p_turb_struct)
[in,out]p_turb_structpointer to the structure to free
◆ cs_turbulence_init_setup()
void cs_turbulence_init_setup ( cs_turbulence_t *  tbs,
cs_equation_t *  mom_eq
[in,out]tbspointer to the structure to initialize
[in]mom_eqpointer to the structure mom_eq
◆ cs_turbulence_init_values()
void cs_turbulence_init_values ( const cs_mesh_t *  mesh,
◆ cs_turbulence_param_create()
cs_turbulence_param_t * cs_turbulence_param_create ( void  )
a pointer to a new allocated cs_turbulence_param_t structure
◆ cs_turbulence_set_shared_from_fv()
void cs_turbulence_set_shared_from_fv ( cs_turbulence_t *  tbs,
bool  is_shared
[in]is_sharedboolean parameter to set
