cs_cdo_quantities.cpp File Reference
#include <array>
#include <float.h>
#include <limits.h>
#include "base/cs_mem.h"
#include "base/cs_array.h"
#include "base/cs_array_reduce.h"
#include "base/cs_halo.h"
#include "base/cs_halo_perio.h"
#include "base/cs_log.h"
#include "base/cs_order.h"
#include "base/cs_parall.h"
#include "cdo/cs_param_cdo.h"
#include "cdo/cs_cdo_quantities.h"
+ Include dependency graph for cs_cdo_quantities.cpp:
long long cs_cdo_quantities_get_time_perfo (void)
 Retrieve the time elapsed to build the cs_cdo_quantities_t structure. More...
void cs_cdo_quantities_set (cs_flag_t option_flag)
 Set which quantities have to be computed. Additionnal quantities are added to cs_cdo_quantities_flag (static variable) More...
void cs_cdo_quantities_set_algo_ccenter (cs_cdo_quantities_cell_center_algo_t algo)
 Set the type of algorithm to use for computing the cell center. More...
cs_cdo_quantities_t * cs_cdo_quantities_build (const cs_mesh_t *m, const cs_mesh_quantities_t *mq, const cs_cdo_connect_t *topo)
 Build a cs_cdo_quantities_t structure. Some quantities are shared with the cs_mesh_quantities_t structure and other are not built according to the given flags in cs_cdo_quantities_flag. More...
cs_cdo_quantities_t * cs_cdo_quantities_free (cs_cdo_quantities_t *cdoq)
 Destroy a cs_cdo_quantities_t structure. More...
void cs_cdo_quantities_log_summary (const cs_cdo_quantities_t *cdoq)
 Summarize generic information about the cdo mesh quantities. More...
void cs_cdo_quantities_dump (const cs_cdo_quantities_t *cdoq)
 Dump a cs_cdo_quantities_t structure (for debuggingpurpose) More...
const cs_real_t * cs_cdo_quantities_get_pvol_fc (const cs_cdo_quantities_t *cdoq, const cs_adjacency_t *c2f)
 Retrieve the portion of volume surrounding each face of a cell. This volume corresponds to a pyramid with base f and apex x_f. If this quantity does not exist, then one computes it and stores it inside the cdoq structures. The computed quantity is scanned with the c2f adjacency structure. More...
void cs_cdo_quantities_compute_pvol_fc (const cs_cdo_quantities_t *cdoq, const cs_adjacency_t *c2f, cs_real_t **p_pvol_fc)
 Compute the portion of volume surrounding each face of a cell. This volume corresponds to a pyramid with base f and apex x_f The computed quantity is scanned with the c2f adjacency. More...
const cs_real_t * cs_cdo_quantities_get_pvol_ec (const cs_cdo_quantities_t *cdoq, const cs_adjacency_t *c2e)
 Retrieve the portion of volume surrounding each edge of a cell. This volume corresponds to an octahedron with a vertical axis defined by the edge. If this quantity does not exist, then one computes it and stores it inside the cdoq structures. The computed quantity is scanned with the c2e adjacency structure. More...
void cs_cdo_quantities_compute_pvol_ec (const cs_cdo_quantities_t *cdoq, const cs_adjacency_t *c2e, cs_real_t **p_pvol_ec)
 Compute the portion of volume surrounding each edge of a cell. The computed quantity is scanned with the c2e adjacency structure. More...
const cs_real_t * cs_cdo_quantities_get_dual_volumes (cs_cdo_quantities_t *cdoq, const cs_cdo_connect_t *connect)
 Compute or retrieve the dual volume surrounding each vertex. The parallel operation (sum reduction) is performed inside this function so that the full dual volume (i.e. taking into account all ranks) is computed. The sum of all the portions of dual cell associated to a vertex in each cell is taken into account. More...
void cs_cdo_quantities_compute_dual_volumes (const cs_cdo_quantities_t *cdoq, const cs_cdo_connect_t *connect, cs_real_t **p_dual_vol)
 Compute the dual volume surrounding each vertex. The parallel operation (sum reduction) is performed inside this function so that the full dual volume (i.e. taking into account all ranks) is computed. The sum of all the portions of dual cell associated to a vertex in each cell is taken into account. More...
void cs_cdo_quantities_compute_i_tef (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_lnum_t f_id, cs_real_t tef[])
 Compute the area of the triangles with basis each edge of the face and apex the face center. Case of interior faces. Storage in agreement with the if2v adjacency structure. More...
void cs_cdo_quantities_compute_b_tef (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_lnum_t bf_id, cs_real_t tef[])
 Compute the area of the triangles with basis each edge of the face and apex the face center. Case of boundary faces. Storage in agreement with the bf2v adjacency structure. More...
void cs_cdo_quantities_compute_i_wvf (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_lnum_t f_id, cs_real_t wvf[])
 Compute the weight related to each vertex of a face. This weight ensures a 2nd order approximation if the face center is the face barycenter. Case of interior faces. More...
void cs_cdo_quantities_compute_b_wvf (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_lnum_t bf_id, cs_real_t wvf[])
 Compute the weight related to each vertex of a face. This weight ensures a 2nd order approximation if the face center is the face barycenter. Case of boundary faces. More...
cs_quant_t cs_quant_set_face (cs_lnum_t f_id, const cs_cdo_quantities_t *cdoq)
 Define a cs_quant_t structure for a primal face (interior or border) More...
cs_nvec3_t cs_quant_set_face_nvec (cs_lnum_t f_id, const cs_cdo_quantities_t *cdoq)
 Retrieve the face surface and its unit normal vector for a primal face (interior or border) More...
cs_quant_t cs_quant_get_edge_center (cs_lnum_t e_id, const cs_cdo_connect_t *topo, const cs_cdo_quantities_t *cdoq)
 Retrieve the edge center for a primal edge (interior or border) More...
cs_nvec3_t cs_quant_set_edge_nvec (cs_lnum_t e_id, const cs_cdo_quantities_t *cdoq)
 Get the normalized vector associated to a primal edge. More...
cs_nvec3_t cs_quant_set_dedge_nvec (cs_lnum_t shift, const cs_cdo_quantities_t *cdoq)
 Get the two normalized vector associated to a dual edge. More...
void cs_quant_dump (FILE *f, cs_lnum_t num, const cs_quant_t q)
 Dump a cs_quant_t structure. More...
static long long cs_cdo_quantities_time = 0
cs_flag_t cs_cdo_quantities_flag = 0
cs_cdo_quantities_cell_center_algo_t cs_cdo_cell_center_algo = CS_CDO_QUANTITIES_BARYC_CENTER
◆ cs_cdo_quantities_build()
cs_cdo_quantities_t * cs_cdo_quantities_build ( const cs_mesh_t *  m,
const cs_mesh_quantities_t *  mq,
const cs_cdo_connect_t *  topo
[in]mpointer to a cs_mesh_t structure
[in]mqpointer to a cs_mesh_quantities_t structure
[in]topopointer to a cs_cdo_connect_t structure
a new allocated pointer to a cs_cdo_quantities_t structure
◆ cs_cdo_quantities_compute_b_tef()
void cs_cdo_quantities_compute_b_tef ( const cs_cdo_connect_t *  connect,
const cs_cdo_quantities_t *  cdoq,
cs_lnum_t  bf_id,
cs_real_t  tef[]
[in]bf_idborder face id
[in,out]tefquantities to compute (pre-allocated)
◆ cs_cdo_quantities_compute_b_wvf()
void cs_cdo_quantities_compute_b_wvf ( const cs_cdo_connect_t *  connect,
cs_lnum_t  bf_id,
cs_real_t  wvf[]
[in,out]wvfquantities to compute (pre-allocated)
◆ cs_cdo_quantities_compute_dual_volumes()
void cs_cdo_quantities_compute_dual_volumes ( const cs_cdo_quantities_t *  cdoq,
cs_real_t **  p_dual_vol
[in]cdoqadditional quantities for CDO schemes
[in]connectadditional connectivities for CDO schemes
[in,out]p_dual_voldouble pointer to the dual volumes related to each vertex. Allocated if nullptr.
◆ cs_cdo_quantities_compute_i_tef()
void cs_cdo_quantities_compute_i_tef ( const cs_cdo_connect_t *  connect,
cs_lnum_t  f_id,
cs_real_t  tef[]
Compute the area of the triangles with basis each edge of the face and apex the face center. Case of interior faces. Storage in agreement with the bf2v adjacency structure.
[in]f_idinterior face id
◆ cs_cdo_quantities_compute_i_wvf()
void cs_cdo_quantities_compute_i_wvf ( const cs_cdo_connect_t *  connect,
cs_lnum_t  f_id,
cs_real_t  wvf[]
◆ cs_cdo_quantities_compute_pvol_ec()
void cs_cdo_quantities_compute_pvol_ec ( const cs_cdo_quantities_t *  cdoq,
const cs_adjacency_t *  c2e,
cs_real_t **  p_pvol_ec
[in]cdoqpointer to cs_cdo_quantities_t structure
[in]c2epointer to the cell --> edges connectivity
[in,out]p_pvol_ecdouble pointer to the edge volume in each cell If not allocated before calling this function, one allocates the array storing the volumes
◆ cs_cdo_quantities_compute_pvol_fc()
void cs_cdo_quantities_compute_pvol_fc ( const cs_cdo_quantities_t *  cdoq,
const cs_adjacency_t *  c2f,
cs_real_t **  p_pvol_fc
Compute the portion of volume surrounding each face of a cell. This volume corresponds to a pyramid with base f and apex x_f The computed quantity is scanned with the c2f adjacency structure.
[in]c2fpointer to the cell --> faces connectivity
[in,out]p_pvol_fcdouble pointer to the face volume in each cell If not allocated before calling this function, one allocates the array storing the volumes
◆ cs_cdo_quantities_dump()
void cs_cdo_quantities_dump ( const cs_cdo_quantities_t *  cdoq)
◆ cs_cdo_quantities_free()
cs_cdo_quantities_t * cs_cdo_quantities_free ( cs_cdo_quantities_t *  cdoq)
[in]cdoqpointer to structure to free
a null pointer
◆ cs_cdo_quantities_get_dual_volumes()
const cs_real_t * cs_cdo_quantities_get_dual_volumes ( cs_cdo_quantities_t *  cdoq,
[in,out]cdoqadditional quantities for CDO schemes
the dual volume associated to each vertex
◆ cs_cdo_quantities_get_pvol_ec()
const cs_real_t * cs_cdo_quantities_get_pvol_ec ( const cs_cdo_quantities_t *  cdoq,
the volume associated to each edge in each cell
◆ cs_cdo_quantities_get_pvol_fc()
const cs_real_t * cs_cdo_quantities_get_pvol_fc ( const cs_cdo_quantities_t *  cdoq,
Retrieve the portion of volume surrounding each face of a cell. This volume corresponds to a pyramid with base f and apex x_f The computed quantity is scanned with the c2f adjacency structure.
the volume associated to each face in each cell
◆ cs_cdo_quantities_get_time_perfo()
long long cs_cdo_quantities_get_time_perfo ( void  )
the value of the time elapsed in ns
◆ cs_cdo_quantities_log_summary()
void cs_cdo_quantities_log_summary ( const cs_cdo_quantities_t *  cdoq)
◆ cs_cdo_quantities_set()
void cs_cdo_quantities_set ( cs_flag_t  option_flag)
[in]option_flagflag to set geometrical quantities to compute
◆ cs_cdo_quantities_set_algo_ccenter()
void cs_cdo_quantities_set_algo_ccenter ( cs_cdo_quantities_cell_center_algo_t  algo)
[in]algotype of algorithm
◆ cs_quant_dump()
void cs_quant_dump ( FILE *  f,
cs_lnum_t  num,
const cs_quant_t  q
[in]fFILE struct (stdout if nullptr)
[in]numentity number related to this quantity struct.
[in]qcs_quant_t structure to dump
◆ cs_quant_get_edge_center()
cs_quant_t cs_quant_get_edge_center ( cs_lnum_t  e_id,
const cs_cdo_connect_t *  topo,
[in]e_idid related to the edfe
a pointer to the edge center coordinates
◆ cs_quant_set_dedge_nvec()
cs_nvec3_t cs_quant_set_dedge_nvec ( cs_lnum_t  shift,
[in]shiftposition in c2f_idx
a pointer to the dual edge normalized vector
◆ cs_quant_set_edge_nvec()
cs_nvec3_t cs_quant_set_edge_nvec ( cs_lnum_t  e_id,
[in]e_idid related to an edge
a pointer to the edge normalized vector
◆ cs_quant_set_face()
cs_quant_t cs_quant_set_face ( cs_lnum_t  f_id,
[in]f_idid related to the face (f_id > n_i_face -> border face)
a initialize structure
◆ cs_quant_set_face_nvec()
cs_nvec3_t cs_quant_set_face_nvec ( cs_lnum_t  f_id,
a pointer to the face normalized vector
◆ cs_cdo_cell_center_algo
◆ cs_cdo_quantities_flag
◆ cs_cdo_quantities_time
static
