cs_cdo_local.h File Reference
#include "cdo/cs_cdo_quantities.h"
#include "cdo/cs_flag.h"
#include "cdo/cs_param_cdo.h"
#include "cdo/cs_sdm.h"
+ Include dependency graph for cs_cdo_local.h:
Classes
struct  cs_cell_builder_t
 Set of local and temporary buffers. More...
struct  cs_cell_sys_t
 Set of arrays and local (small) dense matrices related to a mesh cell This is a key structure for building the local algebraic system. This structure belongs to one thread and only. More...
struct  cs_cell_mesh_t
 Set of local quantities and connectivities related to a mesh cell. More...
struct  cs_face_mesh_t
 Set of local quantities and connectivities related to a mesh face Structure used to get a better memory locality. Map existing structure into a more compact one dedicated to a face. Arrays are allocated to n_max_vbyf (= n_max_ebyf). Face-wise numbering is based on the f2e connectivity. More...
struct  cs_face_mesh_light_t
static bool cs_cell_has_boundary_elements (const cs_cell_builder_t *const cb)
 Check if at least one entity of the cell belongs to the boundary. More...
static short int cs_cell_mesh_get_v (const cs_lnum_t v_id, const cs_cell_mesh_t *const cm)
 Retrieve the vertex id in the cellwise numbering associated to the given vertex id in the mesh numbering. More...
static short int cs_cell_mesh_get_e (const cs_lnum_t e_id, const cs_cell_mesh_t *const cm)
 Retrieve the edge id in the cellwise numbering associated to the given edge id in the mesh numbering. More...
static short int cs_cell_mesh_get_f (const cs_lnum_t f_id, const cs_cell_mesh_t *const cm)
 Retrieve the face id in the cellwise numbering associated to the given face id in the mesh numbering. More...
static void cs_cell_mesh_get_f2v (short int f, const cs_cell_mesh_t *cm, short int *n_vf, short int *v_ids)
 Retrieve the list of vertices attached to a face. More...
static void cs_cell_mesh_get_next_3_vertices (const short int *f2e_ids, const short int *e2v_ids, short int *v0, short int *v1, short int *v2)
 Get the next three vertices in a row from a face to edge connectivity and a edge to vertex connectivity. More...
static bool cs_cell_mesh_is_boundary_face (const cs_cell_mesh_t *cm, const short int f)
 Is the face a boundary one ? More...
void cs_cdo_local_initialize (const cs_cdo_connect_t *connect)
 Allocate global structures used for build system with a cellwise or facewise process. More...
void cs_cdo_local_finalize (void)
 Free global structures related to cs_cell_mesh_t and cs_face_mesh_t structures. More...
cs_cell_sys_t * cs_cell_sys_create (int n_max_dofbyc, int n_max_fbyc, int n_blocks, int *block_sizes)
 Allocate a cs_cell_sys_t structure. More...
void cs_cell_sys_reset (int n_fbyc, cs_cell_sys_t *csys)
 Reset all members related to BC and some other ones in a cs_cell_sys_t structure. More...
void cs_cell_sys_free (cs_cell_sys_t **p_csys)
 Free a cs_cell_sys_t structure. More...
void cs_cell_sys_dump (const char msg[], const cs_cell_sys_t *csys)
 Dump a local system for debugging purpose. More...
cs_cell_builder_t * cs_cell_builder_create (void)
 Allocate cs_cell_builder_t structure. More...
void cs_cell_builder_free (cs_cell_builder_t **p_cb)
 Free a cs_cell_builder_t structure. More...
cs_cell_mesh_t * cs_cell_mesh_create (const cs_cdo_connect_t *connect)
 Allocate and initialize a cs_cell_mesh_t structure. More...
cs_cell_mesh_t * cs_cdo_local_get_cell_mesh (int mesh_id)
 Get a pointer to a cs_cell_mesh_t structure corresponding to mesh id. More...
void cs_cell_mesh_reset (cs_cell_mesh_t *cm)
 Initialize to invalid values a cs_cell_mesh_t structure. More...
void cs_cell_mesh_dump (const cs_cell_mesh_t *cm)
 Dump a cs_cell_mesh_t structure. More...
void cs_cell_mesh_free (cs_cell_mesh_t **p_cm)
 Free a cs_cell_mesh_t structure. More...
void cs_cell_mesh_build (cs_lnum_t c_id, cs_eflag_t build_flag, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_cell_mesh_t *cm)
 Define a cs_cell_mesh_t structure for a given cell id. According to the requested level, some quantities may not be defined;. More...
cs_face_mesh_t * cs_face_mesh_create (short int n_max_vbyf)
 Allocate a cs_face_mesh_t structure. More...
cs_face_mesh_t * cs_cdo_local_get_face_mesh (int mesh_id)
 Get a pointer to a cs_face_mesh_t structure corresponding to mesh id. More...
void cs_face_mesh_free (cs_face_mesh_t **p_fm)
 Free a cs_face_mesh_t structure. More...
void cs_face_mesh_build (cs_lnum_t c_id, cs_lnum_t f_id, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_face_mesh_t *fm)
 Define a cs_face_mesh_t structure for a given face/cell id. More...
void cs_face_mesh_build_from_cell_mesh (const cs_cell_mesh_t *cm, short int f, cs_face_mesh_t *fm)
 Define a cs_face_mesh_t structure for a given cell from a cs_cell_mesh_t structure. v_ids and e_ids are defined in the cell numbering given by cm. More...
cs_face_mesh_light_t * cs_face_mesh_light_create (short int n_max_vbyf, short int n_max_vbyc)
 Allocate a cs_face_mesh_light_t structure. More...
cs_face_mesh_light_t * cs_cdo_local_get_face_mesh_light (int mesh_id)
 Get a pointer to a cs_face_mesh_light_t structure corresponding to mesh id. More...
void cs_face_mesh_light_free (cs_face_mesh_light_t **p_fm)
 Free a cs_face_mesh_light_t structure. More...
void cs_face_mesh_light_build (const cs_cell_mesh_t *cm, short int f, cs_face_mesh_light_t *fm)
 Define a cs_face_mesh_light_t structure starting from a cs_cell_mesh_t structure. More...
cs_cell_mesh_t ** cs_cdo_local_cell_meshes
cs_face_mesh_t ** cs_cdo_local_face_meshes
cs_face_mesh_light_t ** cs_cdo_local_face_meshes_light
◆ cs_cdo_local_finalize()
void cs_cdo_local_finalize ( void  )
◆ cs_cdo_local_get_cell_mesh()
cs_cell_mesh_t * cs_cdo_local_get_cell_mesh ( int  mesh_id)
[in]mesh_idid in the array of pointer to cs_cell_mesh_t struct.
◆ cs_cdo_local_get_face_mesh()
cs_face_mesh_t * cs_cdo_local_get_face_mesh ( int  mesh_id)
[in]mesh_idid in the array of pointer to cs_face_mesh_t struct.
◆ cs_cdo_local_get_face_mesh_light()
cs_face_mesh_light_t * cs_cdo_local_get_face_mesh_light ( int  mesh_id)
[in]mesh_idid in the cs_face_mesh_light_t array
◆ cs_cdo_local_initialize()
void cs_cdo_local_initialize ( const cs_cdo_connect_t *  connect)
◆ cs_cell_builder_create()
cs_cell_builder_t * cs_cell_builder_create ( void  )
a pointer to the new allocated cs_cell_builder_t structure
◆ cs_cell_builder_free()
void cs_cell_builder_free ( cs_cell_builder_t **  p_cb)
[in,out]p_cbpointer of pointer to a cs_cell_builder_t struct
◆ cs_cell_has_boundary_elements()
static bool cs_cell_has_boundary_elements ( const cs_cell_builder_t *const  cb)
inlinestatic
[in]cbpointer to a cs_cell_builder_t structure
true or false
◆ cs_cell_mesh_build()
void cs_cell_mesh_build ( cs_lnum_t  c_id,
cs_cell_mesh_t *  cm
[in]c_idcell id
[in]build_flagindicate which members are really built
[in,out]cmpointer to a cs_cell_mesh_t structure to set
◆ cs_cell_mesh_create()
cs_cell_mesh_t * cs_cell_mesh_create ( const cs_cdo_connect_t *  connect)
a pointer to a new allocated cs_cell_mesh_t structure
◆ cs_cell_mesh_dump()
void cs_cell_mesh_dump ( const cs_cell_mesh_t *  cm)
◆ cs_cell_mesh_free()
void cs_cell_mesh_free ( cs_cell_mesh_t **  p_cm)
[in,out]p_cmpointer of pointer to a cs_cell_mesh_t structure
◆ cs_cell_mesh_get_e()
static short int cs_cell_mesh_get_e ( const cs_lnum_t  e_id,
inlinestatic
[in]e_idvertex id in the mesh numbering
the edge id in the cell numbering or -1 if not found
◆ cs_cell_mesh_get_f()
static short int cs_cell_mesh_get_f ( const cs_lnum_t  f_id,
inlinestatic
[in]f_idface id in the mesh numbering
the face id in the cell numbering or -1 if not found
◆ cs_cell_mesh_get_f2v()
static void cs_cell_mesh_get_f2v ( short int  f,
const cs_cell_mesh_t *  cm,
short int *  n_vf,
short int *  v_ids
inlinestatic
[in]fface id in the cell numbering
[in,out]n_vfpointer of pointer to a cellwise view of the mesh
[in,out]v_idslist of vertex ids in the cell numbering
◆ cs_cell_mesh_get_next_3_vertices()
static void cs_cell_mesh_get_next_3_vertices ( const short int *  f2e_ids,
const short int *  e2v_ids,
short int *  v0,
short int *  v1,
short int *  v2
inlinestatic
[in]f2e_idsface-edge connectivity
[in]e2v_idsedge-vertex connectivity
[in,out]v0id of the first vertex
[in,out]v1id of the second vertex
[in,out]v2id of the third vertex
◆ cs_cell_mesh_get_v()
static short int cs_cell_mesh_get_v ( const cs_lnum_t  v_id,
inlinestatic
[in]v_idvertex id in the mesh numbering
the vertex id in the cell numbering or -1 if not found
◆ cs_cell_mesh_is_boundary_face()
static bool cs_cell_mesh_is_boundary_face ( const cs_cell_mesh_t *  cm,
const short int  f
inlinestatic
[in]fid of the face in the cellwise numbering
true if this is a boundary face otherwise false
◆ cs_cell_mesh_reset()
void cs_cell_mesh_reset ( cs_cell_mesh_t *  cm)
◆ cs_cell_sys_create()
cs_cell_sys_t * cs_cell_sys_create ( int  n_max_dofbyc,
int  n_max_fbyc,
int  n_blocks,
int *  block_sizes
[in]n_max_dofbycmax. number of DoFs at a cell-wise level
[in]n_max_fbycmax. number of faces in a cell
[in]n_blocksnumber of blocks in a row/column
[in]block_sizessize of each block or null. Specific treatment n_blocks = 1.
a pointer to a new allocated cs_cell_sys_t structure
[in]block_sizessize of each block or nullptr. Specific treatment for n_blocks = 1.
◆ cs_cell_sys_dump()
void cs_cell_sys_dump ( const char  msg[],
const cs_cell_sys_t *  csys
[in]msgassociated message to print
[in]csyspointer to a cs_cell_sys_t structure
◆ cs_cell_sys_free()
void cs_cell_sys_free ( cs_cell_sys_t **  p_csys)
[in,out]p_csyspointer of pointer to a cs_cell_sys_t struct.
◆ cs_cell_sys_reset()
void cs_cell_sys_reset ( int  n_fbyc,
[in]n_fbycnumber of faces in a cell
[in,out]csyspointer to the cs_cell_sys_t struct to reset
◆ cs_face_mesh_build()
void cs_face_mesh_build ( cs_lnum_t  c_id,
cs_lnum_t  f_id,
cs_face_mesh_t *  fm
[in]c_idcell id
[in]f_idface id in the mesh structure
[in,out]fmpointer to a cs_face_mesh_t structure to set
◆ cs_face_mesh_build_from_cell_mesh()
void cs_face_mesh_build_from_cell_mesh ( const cs_cell_mesh_t *  cm,
short int  f,
cs_face_mesh_t *  fm
[in]cmpointer to the reference cs_cell_mesh_t structure
[in]fface id in the cs_cell_mesh_t structure
◆ cs_face_mesh_create()
cs_face_mesh_t * cs_face_mesh_create ( short int  n_max_vbyf)
[in]n_max_vbyfmax. number of vertices for a face
a pointer to a new allocated cs_face_mesh_t structure
[in]n_max_vbyfmax. number of vertices fir a face
◆ cs_face_mesh_free()
void cs_face_mesh_free ( cs_face_mesh_t **  p_fm)
[in,out]p_fmpointer of pointer to a cs_face_mesh_t structure
◆ cs_face_mesh_light_build()
void cs_face_mesh_light_build ( const cs_cell_mesh_t *  cm,
short int  f,
cs_face_mesh_light_t *  fm
[in,out]fmpointer to a cs_face_mesh_light_t structure to set
◆ cs_face_mesh_light_create()
cs_face_mesh_light_t * cs_face_mesh_light_create ( short int  n_max_vbyf,
[in]n_max_vbycmax. number of vertices for a cell
a pointer to a new allocated cs_face_mesh_light_t structure
◆ cs_face_mesh_light_free()
void cs_face_mesh_light_free ( cs_face_mesh_light_t **  p_fm)
[in,out]p_fmpointer of pointer to a cs_face_mesh_light_t struct.
◆ cs_cdo_local_cell_meshes
cs_cell_mesh_t** cs_cdo_local_cell_meshes
extern
◆ cs_cdo_local_face_meshes
cs_face_mesh_t** cs_cdo_local_face_meshes
extern
◆ cs_cdo_local_face_meshes_light
cs_face_mesh_light_t** cs_cdo_local_face_meshes_light
extern
