cs_cdo_connect.h File Reference
#include "fvm/fvm_defs.h"
#include "base/cs_base.h"
#include "cdo/cs_flag.h"
#include "base/cs_param_types.h"
#include "mesh/cs_mesh.h"
#include "mesh/cs_mesh_adjacencies.h"
#include "base/cs_range_set.h"
+ Include dependency graph for cs_cdo_connect.h:
Classes
struct  cs_cdo_connect_t
Macros
#define CS_TRIANGLE_CASE   3 /* Number of vertices in a triangle */
static void cs_connect_get_next_3_vertices (const cs_lnum_t *f2e_ids, const cs_lnum_t *e2v_ids, const cs_lnum_t start_idx, cs_lnum_t *v0, cs_lnum_t *v1, cs_lnum_t *v2)
 Get the next three vertices in a row from a face to edge connectivity and a edge to vertex connectivity. More...
cs_cdo_connect_t * cs_cdo_connect_build (cs_mesh_t *mesh, cs_flag_t eb_scheme_flag, cs_flag_t fb_scheme_flag, cs_flag_t cb_scheme_flag, cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag, cs_flag_t hho_scheme_flag, cs_flag_t mac_scheme_flag)
 Allocate and define a new cs_cdo_connect_t structure Range sets and interface sets are allocated and defined according to the value of the different scheme flags. cs_range_set_t structure related to vertices is shared the cs_mesh_t structure (the global one) More...
cs_cdo_connect_t * cs_cdo_connect_free (const cs_mesh_t *mesh, cs_cdo_connect_t *connect)
 Destroy a cs_cdo_connect_t structure. More...
void cs_cdo_connect_log_summary (const cs_cdo_connect_t *connect, cs_flag_t eb_scheme_flag, cs_flag_t vb_scheme_flag, cs_flag_t vcb_scheme_flag)
 Summary of the connectivity information. More...
void cs_cdo_connect_allocate_cw_buffer (const cs_cdo_connect_t *connect)
 Allocate and initialize the cell-wise buffer(s) More...
void cs_cdo_connect_free_cw_buffer (void)
 Free the cell-wise buffer(s) More...
double * cs_cdo_connect_get_cw_buffer (int thr_id)
 Retrieve the cell-wise buffer associated to the current thread. Use cs_get_thread_id when the thread id is not directly available. More...
long long cs_cdo_connect_get_time_perfo (void)
 Retrieve the time elapsed to build the cs_cdo_connect_t structure. More...
void cs_cdo_connect_assign_vtx_ifs_rs (const cs_mesh_t *mesh, int n_vtx_dofs, bool interlaced, cs_interface_set_t **p_ifs, cs_range_set_t **p_rs)
 Allocate and define a cs_range_set_t structure and a cs_interface_set_t structure for schemes with DoFs at vertices. More...
void cs_cdo_connect_assign_face_ifs_rs (const cs_mesh_t *mesh, cs_lnum_t n_faces, int n_face_dofs, cs_interface_set_t **p_ifs, cs_range_set_t **p_rs)
 Allocate and define a cs_range_set_t structure and a cs_interface_set_t structure for schemes with DoFs at faces. More...
cs_interface_set_t * cs_cdo_connect_define_face_interface (const cs_mesh_t *mesh)
 Create and define a new cs_interface_set_t structure on faces. More...
void cs_cdo_connect_discrete_curl (const cs_cdo_connect_t *connect, const cs_real_t *edge_values, cs_real_t **p_curl_values)
 Compute the discrete curl operator across each primal faces. From an edge-based array (seen as circulations) compute a face-based array (seen as fluxes) More...
void cs_cdo_connect_dump (const cs_cdo_connect_t *connect)
 Dump a cs_cdo_connect_t structure for debugging purpose. More...
◆ CS_TRIANGLE_CASE
◆ cs_cdo_connect_allocate_cw_buffer()
void cs_cdo_connect_allocate_cw_buffer ( const cs_cdo_connect_t *  connect)
[in]connectpointer to additional connectivities
◆ cs_cdo_connect_assign_face_ifs_rs()
void cs_cdo_connect_assign_face_ifs_rs ( const cs_mesh_t *  mesh,
cs_lnum_t  n_faces,
int  n_face_dofs,
cs_interface_set_t **  p_ifs,
cs_range_set_t **  p_rs
[in]n_facesnumber of faces (interior + border)
[in]n_face_dofsnumber of DoFs per face
[in,out]p_ifspointer of pointer to a cs_interface_set_t
[in,out]p_rspointer of pointer to a cs_range_set_t
◆ cs_cdo_connect_assign_vtx_ifs_rs()
void cs_cdo_connect_assign_vtx_ifs_rs ( const cs_mesh_t *  mesh,
int  n_vtx_dofs,
bool  interlaced,
[in]n_vtx_dofsnumber of DoFs per vertex
[in]interlacedfalse means a block viewpoint
◆ cs_cdo_connect_build()
cs_cdo_connect_t * cs_cdo_connect_build ( cs_mesh_t *  mesh,
[in,out]meshpointer to a cs_mesh_t structure
[in]eb_scheme_flagmetadata for Edge-based schemes
[in]fb_scheme_flagmetadata for Face-based schemes
[in]cb_scheme_flagmetadata for Cell-based schemes
[in]vb_scheme_flagmetadata for Vertex-based schemes
[in]vcb_scheme_flagmetadata for Vertex+Cell-based schemes
[in]hho_scheme_flagmetadata for HHO schemes
[in]mac_scheme_flagmetadata for MAC schemes
a pointer to a cs_cdo_connect_t structure
DOXYGEN_SHOULD_SKIP_THIS
◆ cs_cdo_connect_define_face_interface()
cs_interface_set_t * cs_cdo_connect_define_face_interface ( const cs_mesh_t *  mesh)
a pointer to a new allocated cs_interface_set_t structure
◆ cs_cdo_connect_discrete_curl()
void cs_cdo_connect_discrete_curl ( const cs_cdo_connect_t *  connect,
const cs_real_t *  edge_values,
cs_real_t **  p_curl_values
[in]edge_valuesarray of values at edges
[in,out]p_curl_valuesarray storing the curl across faces. This array is allocated if necessary.
◆ cs_cdo_connect_dump()
void cs_cdo_connect_dump ( const cs_cdo_connect_t *  connect)
[in]connectpointer to cs_cdo_connect_t structure
◆ cs_cdo_connect_free()
cs_cdo_connect_t * cs_cdo_connect_free ( const cs_mesh_t *  mesh,
[in]meshpointer to a mesh structure
[in,out]connectpointer to additional CDO connectivities
a null pointer
◆ cs_cdo_connect_free_cw_buffer()
void cs_cdo_connect_free_cw_buffer ( void  )
◆ cs_cdo_connect_get_cw_buffer()
double * cs_cdo_connect_get_cw_buffer ( int  thr_id)
[in]thr_idthread_id (0 if no openMP)
a pointer to an allocated auxiliary cell-wise buffer
◆ cs_cdo_connect_get_time_perfo()
long long cs_cdo_connect_get_time_perfo ( void  )
the value of the time elapsed in ns
◆ cs_cdo_connect_log_summary()
void cs_cdo_connect_log_summary ( const cs_cdo_connect_t *  connect,
◆ cs_connect_get_next_3_vertices()
static void cs_connect_get_next_3_vertices ( const cs_lnum_t *  f2e_ids,
const cs_lnum_t *  e2v_ids,
cs_lnum_t *  v0,
cs_lnum_t *  v1,
cs_lnum_t *  v2
inlinestatic
[in]f2e_idsface-edge connectivity
[in]e2v_idsedge-vertex connectivity
[in]start_idxindex from which the current cell infos start
[in,out]v0id of the first vertex
[in,out]v1id of the second vertex
[in,out]v2id of the third vertex
