cs_cdo_bc.h File Reference
#include "base/cs_base.h"
#include "cdo/cs_cdo_quantities.h"
#include "base/cs_param_types.h"
#include "cdo/cs_xdef.h"
+ Include dependency graph for cs_cdo_bc.h:
Classes
struct  cs_cdo_bc_face_t
Macros
#define CS_CDO_BC_DEFAULT_DEF   -1
#define CS_CDO_BC_NEUMANN   (1 << 0)
#define CS_CDO_BC_FULL_NEUMANN   (1 << 1)
#define CS_CDO_BC_HMG_NEUMANN   (1 << 2)
#define CS_CDO_BC_DIRICHLET   (1 << 3)
#define CS_CDO_BC_HMG_DIRICHLET   (1 << 4)
#define CS_CDO_BC_ROBIN   (1 << 5)
#define CS_CDO_BC_TANGENTIAL_DIRICHLET   (1 << 6)
#define CS_CDO_BC_WALL_PRESCRIBED   (1 << 7)
#define CS_CDO_BC_SYMMETRY   (1 << 8)
static void cs_cdo_bc_get_desc (cs_flag_t bc_flag, char *desc)
 Convert a flag into a description. More...
static cs_flag_t cs_cdo_bc_get_flag (cs_param_bc_type_t bc_type)
 Convert a cs_param_bc_type_t into a flag (enable multiple type for a same entity as required for vertices and edges) More...
static bool cs_cdo_bc_is_dirichlet (cs_flag_t flag)
 Check if a flag is associated to a Dirichlet BC (homogeneous or not) More...
static bool cs_cdo_bc_is_neumann (cs_flag_t flag)
 Check if a flag is associated to a Neumann BC (homogeneous or not) More...
static bool cs_cdo_bc_is_sliding (cs_flag_t flag)
 Check if a flag is associated to a sliding boundary. More...
static bool cs_cdo_bc_is_circulation (cs_flag_t flag)
cs_cdo_bc_face_t * cs_cdo_bc_face_define (cs_param_bc_type_t default_bc, bool is_steady, int dim, int n_defs, cs_xdef_t **defs, cs_lnum_t n_b_faces)
 Define the structure which translates the BC definitions from the user viewpoint into a ready-to-use structure for setting the arrays keeping the values of the boundary condition to set. More...
cs_cdo_bc_face_t * cs_cdo_bc_free (cs_cdo_bc_face_t *face_bc)
 Free a cs_cdo_bc_face_t structure. More...
◆ CS_CDO_BC_DEFAULT_DEF
◆ cs_cdo_bc_face_define()
cs_cdo_bc_face_t * cs_cdo_bc_face_define ( cs_param_bc_type_t  default_bc,
bool  is_steady,
int  dim,
int  n_defs,
cs_xdef_t **  defs,
cs_lnum_t  n_b_faces
[in]default_bctype of boundary condition to set by default
[in]is_steadymodification or not of the BC selection in time
[in]dimdimension of the related equation
[in]n_defsnumber of boundary definitions
[in]defslist of boundary condition definition
[in]n_b_facesnumber of border faces
a pointer to a new allocated cs_cdo_bc_face_t structure
◆ cs_cdo_bc_free()
cs_cdo_bc_face_t * cs_cdo_bc_free ( cs_cdo_bc_face_t *  face_bc)
[in,out]face_bcpointer to a cs_cdo_bc_face_t structure
a null pointer
◆ cs_cdo_bc_get_desc()
static void cs_cdo_bc_get_desc ( cs_flag_t  bc_flag,
char *  desc
inlinestatic
[in]bc_flagflag of boundary condition
[in,out]descstring storing the description of the BC
◆ cs_cdo_bc_get_flag()
static cs_flag_t cs_cdo_bc_get_flag ( cs_param_bc_type_t  bc_type)
inlinestatic
[in]bc_typepredefined type of boundary condition
a flag corresponding to the given type of boundary condition
◆ cs_cdo_bc_is_circulation()
static bool cs_cdo_bc_is_circulation ( cs_flag_t  flag)
inlinestatic
[in]flagflag to test
true or false
◆ cs_cdo_bc_is_dirichlet()
static bool cs_cdo_bc_is_dirichlet ( cs_flag_t  flag)
inlinestatic
true or false
◆ cs_cdo_bc_is_neumann()
static bool cs_cdo_bc_is_neumann ( cs_flag_t  flag)
inlinestatic
true or false
◆ cs_cdo_bc_is_sliding()
static bool cs_cdo_bc_is_sliding ( cs_flag_t  flag)
inlinestatic
true or false
