cs_atmo_ground_model.h File Reference
+ Include dependency graph for cs_atmo_ground_model.h:
Classes
struct  cs_plant_option_t
void cs_atmo_ground_initialize (void)
 Build constants and variables to describe ground model. More...
void cs_atmo_ground_cat (int call_stage)
 Ground - atmosphere parameters computed from a "Land use" file. More...
void cs_ground_model (void)
 Compute ground and interface values using Deardorff force restore method. More...
cs_plant_option_t * cs_glob_plant_option
◆ cs_atmo_ground_cat()
void cs_atmo_ground_cat ( int  call_stage)
[in]call_stagefirst pass to set default values, second pass to perform some checks and log
◆ cs_atmo_ground_initialize()
void cs_atmo_ground_initialize ( void  )
◆ cs_ground_model()
void cs_ground_model ( void  )
◆ cs_glob_plant_option
cs_plant_option_t* cs_glob_plant_option
extern
