cs_atmo_aerosol_ssh.cpp File Reference
#include <errno.h>
#include <ctype.h>
#include <stdarg.h>
#include <float.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "atmo/cs_air_props.h"
#include "base/cs_base.h"
#include "cdo/cs_domain.h"
#include "base/cs_field.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parall.h"
#include "base/cs_post.h"
#include "atmo/cs_atmo.h"
#include "atmo/cs_atmo_chemistry.h"
#include "atmo/cs_atmo_aerosol_ssh.h"
+ Include dependency graph for cs_atmo_aerosol_ssh.cpp:
void cs_atmo_aerosol_ssh_initialize (void)
 This function initializes SSH-aerosol. More...
void cs_atmo_aerosol_ssh_finalize (void)
 This function finalizes SSH-aerosol. More...
void cs_atmo_aerosol_ssh_compute_numbers (cs_real_t *dlconc0)
 This function computes the number of aerosols using the given array. More...
void cs_atmo_aerosol_ssh_set_t_p_h (cs_real_t *T, cs_real_t *P, cs_real_t *yw)
 This function takes as input absolute temperature T total pressure P water mass fraction yw It computes absolute temperature relative humidity Then updates the humidity in SSH. More...
void cs_atmo_aerosol_ssh_set_aero (cs_real_t *array)
 This function uses the given array to update the aerosol concentrations and numbers in SSH-aerosol. More...
void cs_atmo_aerosol_ssh_get_aero (cs_real_t *array)
 This function fills the given array with aerosol concentrations and numbers from SSH-aerosol. More...
void cs_atmo_aerosol_ssh_set_gas (cs_real_t *array)
 This function uses the given array to update the gas concentrations in SSH-aerosol. More...
void cs_atmo_aerosol_ssh_get_gas (cs_real_t *array)
 This function fills the given array with gas concentrations from SSH-aerosol. More...
void cs_atmo_aerosol_ssh_time_advance (void)
 This function computes a time step of gaseous chemistry and aerosols dynamic using SSH-aerosol. More...
◆ cs_atmo_aerosol_ssh_compute_numbers()
void cs_atmo_aerosol_ssh_compute_numbers ( cs_real_t *  dlconc0)
◆ cs_atmo_aerosol_ssh_finalize()
void cs_atmo_aerosol_ssh_finalize ( void  )
◆ cs_atmo_aerosol_ssh_get_aero()
void cs_atmo_aerosol_ssh_get_aero ( cs_real_t *  array)
◆ cs_atmo_aerosol_ssh_get_gas()
void cs_atmo_aerosol_ssh_get_gas ( cs_real_t *  array)
◆ cs_atmo_aerosol_ssh_initialize()
void cs_atmo_aerosol_ssh_initialize ( void  )
◆ cs_atmo_aerosol_ssh_set_aero()
void cs_atmo_aerosol_ssh_set_aero ( cs_real_t *  array)
◆ cs_atmo_aerosol_ssh_set_gas()
void cs_atmo_aerosol_ssh_set_gas ( cs_real_t *  array)
◆ cs_atmo_aerosol_ssh_set_t_p_h()
void cs_atmo_aerosol_ssh_set_t_p_h ( cs_real_t *  T,
cs_real_t *  P,
cs_real_t *  yw
◆ cs_atmo_aerosol_ssh_time_advance()
void cs_atmo_aerosol_ssh_time_advance ( void  )
