cs_host_context Class Reference
#include <cs_dispatch.h>
+ Inheritance diagram for cs_host_context:
+ Collaboration diagram for cs_host_context:
Public Member Functions
 cs_host_context ()
void set_n_min_per_cpu_thread (cs_lnum_t n)
 Set minimum number of elements threshold for CPU multithread execution. More...
cs_lnum_t n_min_per_cpu_thread (void)
 Get minimum number of elements threshold for CPU multithread execution. More...
void set_n_cpu_threads (int n)
 Set number of threads for CPU multithread execution. More...
int n_cpu_threads (void)
 Get number of threads for CPU multithread execution (-1 if automatic) More...
template<class F , class... Args>
bool parallel_for (cs_lnum_t n, F &&f, Args &&... args)
 Iterate using a plain omp parallel for. More...
template<class M , class F , class... Args>
bool parallel_for_i_faces (const M *m, F &&f, Args &&... args)
bool parallel_for_b_faces (const M *m, F &&f, Args &&... args)
template<class T , class F , class... Args>
bool parallel_for_reduce_sum (cs_lnum_t n, T &sum, F &&f, Args &&... args)
 Plain OpenMP parallel reduction with simple sum. More...
template<class T , class R , class F , class... Args>
bool parallel_for_reduce (cs_lnum_t n, T &result, R &reducer, F &&f, Args &&... args)
 OpenMP parallel reduction with general reducer. More...
template<class... Args>
bool wait (void)
 Wait upon completion. More...
template<class M >
bool try_get_parallel_for_i_faces_sum_type (const M *m, cs_dispatch_sum_type_t &st)
template<class M >
bool try_get_parallel_for_b_faces_sum_type (const M *m, cs_dispatch_sum_type_t &st)
- Public Member Functions inherited from cs_dispatch_context_mixin< cs_host_context >
decltype(auto) parallel_for (cs_lnum_t n, F &&f, Args &&... args)=delete
decltype(auto) parallel_for_i_faces (const M *m, F &&f, Args &&... args)
decltype(auto) parallel_for_b_faces (const M *m, F &&f, Args &&... args)
decltype(auto) parallel_for_reduce_sum (cs_lnum_t n, T &sum, F &&f, Args &&... args)=delete
decltype(auto) parallel_for_reduce (cs_lnum_t n, T &r, R &reducer, F &&f, Args &&... args)=delete
decltype(auto) wait (void)=delete
Constructor & Destructor Documentation
◆ cs_host_context()
cs_host_context ( )
inline
Member Function Documentation
◆ n_cpu_threads()
int n_cpu_threads ( void  )
inline
◆ n_min_per_cpu_thread()
cs_lnum_t n_min_per_cpu_thread ( void  )
inline
◆ parallel_for()
bool parallel_for ( cs_lnum_t  n,
F &&  f,
Args &&...  args
inline
◆ parallel_for_b_faces()
bool parallel_for_b_faces ( const M *  m,
F &&  f,
Args &&...  args
inline
Loop over the boundary faces of a mesh using a specific numbering that avoids conflicts between threads.
◆ parallel_for_i_faces()
bool parallel_for_i_faces ( const M *  m,
F &&  f,
Args &&...  args
inline
Loop over the interior faces of a mesh using a specific numbering that avoids conflicts between threads.
◆ parallel_for_reduce()
bool parallel_for_reduce ( cs_lnum_t  n,
T &  result,
R &  reducer,
F &&  f,
Args &&...  args
inline
◆ parallel_for_reduce_sum()
bool parallel_for_reduce_sum ( cs_lnum_t  n,
T &  sum,
F &&  f,
Args &&...  args
inline
◆ set_n_cpu_threads()
void set_n_cpu_threads ( int  n)
inline
◆ set_n_min_per_cpu_thread()
void set_n_min_per_cpu_thread ( cs_lnum_t  n)
inline
◆ try_get_parallel_for_b_faces_sum_type()
bool try_get_parallel_for_b_faces_sum_type ( const M *  m,
cs_dispatch_sum_type_t &  st
inline
◆ try_get_parallel_for_i_faces_sum_type()
bool try_get_parallel_for_i_faces_sum_type ( const M *  m,
inline
◆ wait()
bool wait ( void  )
inline
The documentation for this class was generated from the following file:
