mdspan< T, N, L > Class Template Reference
#include <cs_mdspan.h>
+ Collaboration diagram for mdspan< T, N, L >:
Public Member Functions
CS_F_HOST_DEVICE mdspan ()
 Default constructor method leading to "empty container". More...
template<typename... Args>
CS_F_HOST_DEVICE mdspan (T *data, Args... indices)
 Constructor method using only global size (works for N=1). More...
CS_F_HOST_DEVICE mdspan (T *data, const cs_lnum_t(&dims)[N])
 Constructor method using dimensions. More...
CS_F_HOST_DEVICE mdspan (const mdspan &other)
 Constructor method using copy. May be a shallow copy. More...
CS_F_HOST mdspan (mdspan &&other)
 Move constructor. More...
CS_F_HOST_DEVICE ~mdspan ()
 Desstructor method using dimensions. More...
CS_F_HOST mdspan & operator= (const mdspan &other)
 Assignment operator. More...
CS_F_HOST mdspan & operator= (mdspan &&other)
CS_F_HOST_DEVICE T & operator[] (cs_lnum_t i)
 Overloaded [] operator to access the ith value (val[i]). More...
CS_F_HOST_DEVICE T & operator[] (cs_lnum_t i) const
template<typename Id1 >
CS_F_HOST_DEVICE std::enable_if_t< cs::always_true< Id1 >::value &&N==1, T & > operator() (Id1 i)
 Overloaded () operator to access the ith value (val[i]). More...
CS_F_HOST_DEVICE std::enable_if_t< cs::always_true< Id1 >::value &&N==1, T & > operator() (Id1 i) const
template<typename Id1 , typename Id2 >
CS_F_HOST_DEVICE std::enable_if_t< cs::always_true< Id1, Id2 >::value &&N==2, T & > operator() (Id1 i, Id2 j)
 Overloaded () operator to access the (i,j)-th value couple. More...
CS_F_HOST_DEVICE std::enable_if_t< cs::always_true< Id1, Id2 >::value &&N==2, T & > operator() (Id1 i, Id2 j) const
CS_F_HOST_DEVICE std::enable_if_t< cs::always_true< Args... >::value &&(N!=2) &&(N!=1), T & > operator() (Args... indices)
 Overloaded () operator to access the (i,j,k)-th value tuple. More...
CS_F_HOST_DEVICE std::enable_if_t< cs::always_true< Args... >::value &&(N!=2) &&(N!=1), T & > operator() (Args... indices) const
CS_F_HOST_DEVICE cs_lnum_t size ()
 Getter for total size. More...
CS_F_HOST_DEVICE cs_lnum_t size () const
CS_F_HOST_DEVICE cs_lnum_t extent (int i)
 Getter for extent along a given dimension. More...
CS_F_HOST_DEVICE cs_lnum_t extent (int i) const
CS_F_HOST_DEVICE T * data ()
 Getter for data raw pointer. More...
template<typename U >
CS_F_HOST_DEVICE U * data ()
 Getter for data raw pointer with recast (casts T* to U*) More...
CS_F_HOST_DEVICE mdspan< T, N-sizeof...(Args), L > sub_view (Args... indices)
 Getter for a subspan based on first dimension. More...
CS_F_HOST_DEVICE T * sub_array (Args... indices)
 Get sub array based on index. More...
CS_F_HOST void set_to_val (T val, const cs_lnum_t n_vals=-1)
 Set all values of the data array to a constant value. More...
CS_F_HOST void set_to_val (cs_dispatch_context &ctx, T val, const cs_lnum_t n_vals=-1)
 Set all values of the data array to a constant value while providing a dispatch context. It is up to the call to synchronize the context after this call. More...
CS_F_HOST void set_to_val_on_subset (T val, const cs_lnum_t n_elts, const cs_lnum_t elt_ids[])
 Set subset of values of the data array to a constant value. More...
CS_F_HOST void set_to_val_on_subset (cs_dispatch_context &ctx, T val, const cs_lnum_t n_elts, const cs_lnum_t elt_ids[])
 Set a subset of values of the data array to a constant value while providing a dispatch context. It is up to the call to synchronize the context after this call. More...
CS_F_HOST_DEVICE void zero ()
 Set all values of the data array to 0. More...
CS_F_HOST_DEVICE void zero (cs_dispatch_context &ctx)
CS_F_HOST_DEVICE void copy_data (T *data, const cs_lnum_t n_vals=-1)
 Copy data from raw pointer, we suppose that data size is same as that of the array. More...
CS_F_HOST_DEVICE void copy_data (const T *data, const cs_lnum_t n_vals=-1)
 Copy data from const raw pointer, we suppose that data size is same as that of the array. More...
CS_F_HOST_DEVICE void copy_data (mdspan &other, const cs_lnum_t n_vals=-1)
 Copy data from another mdspan, we suppose that data size is same as that of the array. An assert test the sizes in debug. More...
CS_F_HOST_DEVICE void copy_data (cs_dispatch_context &ctx, T *data, const cs_lnum_t n_vals=-1)
 Copy data from raw pointer, we suppose that data size is same as that of the array. A dispatch_context is provided, hence no implicit synchronization which should be done by the caller. More...
CS_F_HOST_DEVICE void copy_data (cs_dispatch_context &ctx, const T *data, const cs_lnum_t n_vals=-1)
 Copy data from const raw pointer, we suppose that data size is same as that of the array. A dispatch_context is provided, hence no implicit synchronization which should be done by the caller. More...
CS_F_HOST_DEVICE void copy_data (cs_dispatch_context &ctx, mdspan &other, const cs_lnum_t n_vals=-1)
Friends
template<class _T_ , int _N_, layout _L_>
class array
CS_F_HOST friend void swap (mdspan &first, mdspan &second)
 Class swap operator used for assignment or move. More...
Constructor & Destructor Documentation
◆ mdspan() [1/5]
◆ mdspan() [2/5]
CS_F_HOST_DEVICE mdspan ( T *  data,
Args...  indices
inline
[in]datadata pointer (raw)
[in]indicestotal size of data (1D)
◆ mdspan() [3/5]
const cs_lnum_t(&)  dims[N]
inline
[in]dimsarray of sizes along dimensions
◆ mdspan() [4/5]
CS_F_HOST_DEVICE mdspan ( const mdspan< T, N, L > &  other)
inline
◆ mdspan() [5/5]
CS_F_HOST mdspan ( mdspan< T, N, L > &&  other)
inline
Move constructor.
[in]otherreference to other instance
◆ ~mdspan()
CS_F_HOST_DEVICE ~mdspan ( )
inline
Member Function Documentation
◆ copy_data() [1/6]
CS_F_HOST_DEVICE void copy_data ( const T *  data,
const cs_lnum_t  n_vals = -1
inline
[in]dataPointer to copy
[in]n_valsNumber of values to copy. If -1, default, we use array size
◆ copy_data() [2/6]
CS_F_HOST_DEVICE void copy_data ( cs_dispatch_context &  ctx,
const T *  data,
inline
[in]ctxReference to dispatch context
◆ copy_data() [3/6]
mdspan< T, N, L > &  other,
inline
[in]otherReference to another mdspan object
◆ copy_data() [4/6]
T *  data,
inline
◆ copy_data() [5/6]
CS_F_HOST_DEVICE void copy_data ( mdspan< T, N, L > &  other,
inline
◆ copy_data() [6/6]
CS_F_HOST_DEVICE void copy_data ( T *  data,
inline
◆ data() [1/2]
CS_F_HOST_DEVICE T * data ( )
inline
raw pointer
◆ data() [2/2]
CS_F_HOST_DEVICE U * data ( )
inline
Template Parameters
U: data type used to cast T* into U*
raw pointer (U*)
◆ extent() [1/2]
CS_F_HOST_DEVICE cs_lnum_t extent ( int  i)
inline
extent.
◆ extent() [2/2]
CS_F_HOST_DEVICE cs_lnum_t extent ( int  i) const
inline
extent.
◆ operator()() [1/6]
CS_F_HOST_DEVICE std::enable_if_t< cs::always_true< Args... >::value &&(N!=2) &&(N!=1), T & > operator() ( Args...  indices)
inline
const reference to the (i,j,k)-th value
[in]indicesInput arguments (parameter pack)
◆ operator()() [2/6]
CS_F_HOST_DEVICE std::enable_if_t< cs::always_true< Args... >::value &&(N!=2) &&(N!=1), T & > operator() ( Args...  indices) const
inline
◆ operator()() [3/6]
CS_F_HOST_DEVICE std::enable_if_t< cs::always_true< Id1 >::value &&N==1, T & > operator() ( Id1  i)
inline
raw pointer to the i-th value
[in]iIndex of value to get
◆ operator()() [4/6]
CS_F_HOST_DEVICE std::enable_if_t< cs::always_true< Id1 >::value &&N==1, T & > operator() ( Id1  i) const
inline
◆ operator()() [5/6]
CS_F_HOST_DEVICE std::enable_if_t< cs::always_true< Id1, Id2 >::value &&N==2, T & > operator() ( Id1  i,
Id2  j
inline
reference to the (i,j)-th value
[in]iIndex along first dimension
[in]jIndex along second dimension
◆ operator()() [6/6]
Id2  j
) const
inline
const reference to the (i,j)-th value
◆ operator=() [1/2]
CS_F_HOST mdspan & operator= ( const mdspan< T, N, L > &  other)
inline
◆ operator=() [2/2]
CS_F_HOST mdspan & operator= ( mdspan< T, N, L > &&  other)
inline
◆ operator[]() [1/2]
CS_F_HOST_DEVICE T & operator[] ( cs_lnum_t  i)
inline
◆ operator[]() [2/2]
CS_F_HOST_DEVICE T & operator[] ( cs_lnum_t  i) const
inline
◆ set_to_val() [1/2]
CS_F_HOST void set_to_val ( cs_dispatch_context &  ctx,
T  val,
inline
[in]valValue to set to entire data array.
◆ set_to_val() [2/2]
CS_F_HOST void set_to_val ( T  val,
inline
◆ set_to_val_on_subset() [1/2]
CS_F_HOST void set_to_val_on_subset ( cs_dispatch_context &  ctx,
T  val,
inline
[in]n_eltsNumber of values to set.
[in]elt_idslist of ids in the subset or null (size:n_elts)
◆ set_to_val_on_subset() [2/2]
CS_F_HOST void set_to_val_on_subset ( T  val,
inline
◆ size() [1/2]
CS_F_HOST_DEVICE cs_lnum_t size ( )
inline
total size.
◆ size() [2/2]
CS_F_HOST_DEVICE cs_lnum_t size ( ) const
inline
total size.
◆ sub_array()
CS_F_HOST_DEVICE T * sub_array ( Args...  indices)
inline
◆ sub_view()
CS_F_HOST_DEVICE mdspan< T, N-sizeof...(Args), L > sub_view ( Args...  indices)
inline
pointer
◆ zero() [1/2]
CS_F_HOST_DEVICE void zero ( )
inline
◆ zero() [2/2]
CS_F_HOST_DEVICE void zero ( cs_dispatch_context &  ctx)
inline
Friends And Related Function Documentation
◆ array
friend class array
friend
◆ swap
CS_F_HOST friend void swap ( mdspan< T, N, L > &  first,
mdspan< T, N, L > &  second
friend
[in]firstreference to first instance to swap
[in]secondreference to second instance to swap
The documentation for this class was generated from the following file:
