bft_backtrace.cpp File Reference
#include <stdarg.h>
#include "bft/bft_backtrace.h"
+ Include dependency graph for bft_backtrace.cpp:
bft_backtrace_t * bft_backtrace_create (void)
 Build a backtrace description structure. More...
bft_backtrace_t * bft_backtrace_destroy (bft_backtrace_t *bt)
 Free a backtrace description structure. More...
void bft_backtrace_demangle (bft_backtrace_t *bt)
 Demangle a backtrace description structure (for C++). More...
int bft_backtrace_size (const bft_backtrace_t *bt)
 Return the depth of a backtrace. More...
const char * bft_backtrace_file (bft_backtrace_t *bt, int depth)
 Return file name associated with a backtrace at a given depth. More...
const char * bft_backtrace_function (bft_backtrace_t *bt, int depth)
 Return function name associated with a backtrace at a given depth. More...
const char * bft_backtrace_address (bft_backtrace_t *bt, int depth)
 Return address associated with a backtrace at a given depth. More...
void bft_backtrace_print (int start_depth)
 Print a backtrace. More...
bft_backtrace_print_t * bft_backtrace_print_get (void)
 Returns backtrace print function. More...
void bft_backtrace_print_set (bft_backtrace_print_t *const fct)
 Sets a backtrace print function. More...
◆ bft_backtrace_address()
const char * bft_backtrace_address ( bft_backtrace_t *  bt,
int  depth
[in]btpointer to backtrace description structure.
[in]depthindex in backtrace structure (< bft_backtrace_size(bt)).
address at the given depth, or nullptr.
◆ bft_backtrace_create()
bft_backtrace_t * bft_backtrace_create ( void  )
pointer to bft_backtrace_t backtrace descriptor (nullptr in case of error, or if backtracing is unavailable on this architecture).
◆ bft_backtrace_demangle()
void bft_backtrace_demangle ( bft_backtrace_t *  bt)
[in,out]btpointer to backtrace description structure.
◆ bft_backtrace_destroy()
bft_backtrace_t * bft_backtrace_destroy ( bft_backtrace_t *  bt)
null pointer.
◆ bft_backtrace_file()
const char * bft_backtrace_file ( bft_backtrace_t *  bt,
int  depth
file name at the given depth, or nullptr.
◆ bft_backtrace_function()
const char * bft_backtrace_function ( bft_backtrace_t *  bt,
int  depth
function name at the given depth, or nullptr.
◆ bft_backtrace_print()
void bft_backtrace_print ( int  start_depth)
Print a backtrace.
[in]start_depthdepth of backtrace at which to start printing (0 for all, including backtrace print function)
◆ bft_backtrace_print_get()
bft_backtrace_print_t * bft_backtrace_print_get ( void  )
pointer to the backtrace print function.
◆ bft_backtrace_print_set()
void bft_backtrace_print_set ( bft_backtrace_print_t *const  fct)
[in]fctpointer to a bft_backtrace_print_t type function.
◆ bft_backtrace_size()
int bft_backtrace_size ( const bft_backtrace_t *  bt)
backtrace depth.
