Turbomachinery Test Case
mortbauer
Post by mortbauer »
Would be possible to get some test cases for turbomachinery, as described in the presentation of last years user meeting for example http://code-saturne.org/cms/sites/defau ... U_2013.pdf or also in this years user meeting http://code-saturne.org/cms/sites/defau ... 014-12.pdf. The point is that i'm struggling to get a convergent solution for my turbomachinery case and would like to see the used parameters.
Thankfull for any help
Martin Ortbauer
Re: Turbomachinery Test Case
The 2014 and 2013 versions of rotor-stator coupling are quite different. The new (since version 3.2) mode uses mesh joining, the older one code coupling (it is still available in the current version).
I believe there may be examples of the old coupling-based model on this forum, if we check old-enough posts. There are examples of the new mode in posts from last spring.
I'll check which small cases may be published on this forum, and try to post one within a day or 2.
