Comparison of two 3D approaches for atmospheric dispersion
Commanay Julien
Post by Commanay Julien »
Dear friends,
Please find enclosed some comparisons performed between two 3D approaches for atmospheric
dispersion. These models are Code Saturne (CFD RANS) and a LPDM (Lagrangian Particle Dispersion Model) called MSS.
We performed this comparison in the field of a working group dedicated to 3D modelling of atmospheric dispersion (French Ministry of Environment) on a “virtual site”, which means that no experimental data are available.
This case involves a gaseous release of propane (dense gas) oriented in the direction of an obstacle during 10 minutes. Some obstacles (buildings and a long wall) are located within the computational domain.
Input profiles of wind, turbulence and temperature are related to a stable weather condition (stability F in Pasquill classification and 3 m/s at 10 m above ground level).
Videos should be here-after. The same scales have been considered for concentrations at 0.5m above ground level and isosurfaces are both related to lower flammable limit of propane.
Regards.
LPDM_LFL.avi
(355.35 KiB) Downloaded 1377 times
Code_Saturne_LFL.avi
(5.86 MiB) Downloaded 1360 times
LPDM_50CM.avi
(2.13 MiB) Downloaded 1373 times
Code_Saturne_50CM.avi
(8.29 MiB) Downloaded 1360 times
