Radiative transfer module with CS-2.0-rc2
Posted: Wed Jul 28, 2010 12:59 pm
Hi all,
I recently installed the new version of code saturne 2.0-rc2 on my computer, and I'm having some trouble using the radiative transfer module.
The case I am modelling is the flow and heat transfer in an autoclave. I have flow entering and leaving the autoclave, and grey/black walls with fixed external temperature, for which I know the emissivity, conductivity and thickness. The inlet face has a fixed temperature too. The outlet is free. I have adiabatic walls too. The problem is specified using the GUI and usray1 and usray2.
When running the calculation, I have this kind of error message :
@ @@ ATTENTION : ARRET A L'ENTREE DES DONNEES RAYONNEMENT @ ========= @ XLAMP, EPAP, TEXTP NE DOIVENT PAS ETRE RENSEIGNES @ AVEC ISOTHP = IFREFL
which is weird because there is no reflective wall (IFREFL).
I tried the patch for cs-2.0-rc1 I found on this post Radiative transfers P1-model but it doesn't work.
I tried running the same case with cs-1.4.b without any problem.
I attach here my usray1, usray2 and xml files.
Can you tell me what I should do to solve this problem ?
Thank you very much in advance,
Alicia
Alicia
