Visualizing values associated with mesh quality criteria
finzeo
Post by finzeo »
Hi all!
I know that using the "mesh quality criteria only" execution mode you can obtain logfiles corresponding to the mesh quality criteria check. Is there any way to additionally be able to view fields associated with these criteria? (e.g.: non-orthogonality, offset, etc.). The objective is to be able to graphically identify where the drawbacks are, to know where to improve the mesh.
Thank you so much.
finzeo
Re: Visualizing values associated with mesh quality criteria
Post by finzeo »
(I ask this although a similar question was asked in other posts, because in the ones I saw the answer was that it was enough to use that execution mode to be able to view it, but I would not be seeing it in Paraview)
I do not understand if you tested this and do not see variables or did not try based on a previous reply...
finzeo
Post by finzeo »
I'm testing it and I don't see the variables related to bad cells in Paraview (I apologize if I confused this with the image I sent, which was meant to illustrate what I'm trying to achieve in ParaView and corresponds to a user who does not have this problem). Only the "mpi_rank" field is generated when I run a code_saturne case in "mesh quality criteria" mode.
I tried exporting in different formats (ensight, med and cgns), but with none of them I can see the bad cells fields.
Could this issue be specific to version 8.0? (I'm currently using that version).
I attach my setup.xml, run_solver.log and some suspicious error files.
run_solver.log
(15.88 KiB) Downloaded 802 times
error_files.zip
(1.72 KiB) Downloaded 814 times
setup.xml
(11.94 KiB) Downloaded 825 times
It seems you did run in "quality criteria" mode (based on your log), and you have a crash in boundary condition settings (which is strange), although that mode is set in the XML file.
Did you run using the script or directly in a prepared run directory ? In which case you need to use the proper command line option to run in that mode (as described in the documentation).
finzeo
Post by finzeo »
Thank you, now it works.
For some reason, if I reused the setup.xml file that I used for a standard run, but only changing the execution mode to "mesh quality criteria", settings typical of a standard run remained in the xml file (but hidden in the GUI).
Then, when the corresponding postprocessing was run, a run_solver file was generated that did not seems to be set for such run mode.
The solution was simply to use a new empty setup.xml file.
Yes, this is because this execution mode info in the xml file is actually used by the script (not the code) and transformed into a command line option. Wich can be practical when you know how it works and run quick tests in the same directory, surprising otherwise...
This is also something we would like to improve (make those criteria visualizable individually even in a regular computation), but there are other things higher in out todo list....
