Density in the governing equations
Ruonan
Post by Ruonan »
Dear developers,
Could you please help to confirm the form of the momentum equation in Code_Saturne?
or
Because I want to add a centrifugal buoyancy source term in the momentum equation. I want to make sure whether to add or , depending on which form the momentum equation is.
Thank you!
Bonne journée,
Ruonan
Re: Density in the governing equations
I do not think we use adimensioned equations, so the second option would be correct (though i invite you to check on a verification case with rho much greater that or much smaller than 1 once you have added your term).
I'll let others more expert in the numerical aspects of the code correct me if needed.
