I have an error message with CS_2.1.4 and radiative calculation.
I run a radiative calculation with CS_2.0.0, there is no problem.
But the same mesh with CS_2.1.4 bug after 4 iterations.
Radiative parameters:
- Discrete ordiantes method
- 128 directions for angular discretisation
- absorption coefficient = 0m-1
I have an error file with "Signal SIGFPE (exception en virgule flottante) intercepté !"
I have read this could be a division by zero because of the mesh, but the same mesh works with CS_2.1.0.
Futhermore, when I run a calculation without radiative with CS_2.1.4 and there is no bug.
The problem is not with my mesh.
I didn't see, in the user guide, specific modification between the 2 versions for radiative calculation.
Do you know if there is a tutorial or a Flow modeling examples which use radiative.(In order to test my CS_2.14 installation)
Best Regards
Alexandre
radiative and CS_2.1.4
- PieceJointe.zip
- (2.91 KiB) Downloaded 287 times
Re: radiative and CS_2.1.4
Do you use user subroutines, or just the XML ? As version 2.1 is an intermediate development release and has not been tested as much as 2.0, you might have found a bug.
Could you post your case setup (mesh xml, and user subroutines) for both versions 2.0 and 2.1, so we may compare ?
Sorry I can't give you the mesh.
But I will adapt the tutorial "Full domain" in order to make a radiative calculation.
Or do you know if there is a tuto or a Flow modeling examples which use radiative.
Alexandre
Alexandre
I have adapt tuto Full domain.
I still have a problem with CS_2.1.4.
CS_2.1.4 is not installed on the same machine.
Thanks again for your help.
Alexandre
Alexandre
- CS.zip
- (70.69 KiB) Downloaded 271 times
I have found the bug, and it also seems to also affect version 2.0 (even though it does not cause a crash, it may lead to incorrect boundary conditions, so probably incorrect results).
We were ready to release 2.1.6, 2.0.5 (and 2.2.0 later in the week); but I'll check with colleagues if they are ok with the fix tomorrow and get the fix in those releases.
In the meantime, line 1025 of src/gui/cs_radiative_transfer.c, if you replace (*ivart) by (*ivart -1), you should fix this bug (but you should do the same at line 1037 of src/base/cs_gui_radiative_transfer.c in version 2.0 before you compare results).
Thanks for your help.
I will make the modifications in the CS_2.1.4.
I will let you know.
Alexandre
Alexandre
I would like to know if the bug is fix in the version 2.2.1.
Alexandre
Alexandre
Yes the bug is fixed.
SVN log:
JF
SVN log:
Regards,Merge rev. 3227 from trunk (fix array index for radiative transfer using GUI).
JF
Ok, thank you
Alexandre
Alexandre
