Cavity flow for Re>1000
Posted: Mon Jun 22, 2020 10:14 pm
Hi all
I have reproduced the results described in:
https://www.code-saturne.org/cms/sites/ ... y-flow.pdf
As in that document I find that the results of the simulation agree quite well with results published by Ghia et al 1982 for Re=1000. I found the same when I reduced the Reynolds number to 100 (by increasing mu to 0.01) (Ghia's paer includes tabulated balues for Re= 100, 1000, 5000 and 10000). When I tried Reynolds numbers of 5000 and 10000, I see significant differences between the code-saturne simulations and Ghia's results, as well as between code_saturne and a 2d finite element code (that agrees well with Ghia). I have tried increasing the resolution to 129x129 (the resolution used in the Ghia study), and I have tried running the simulation for longer than the 400 cycles indicated in the tutorial notes. Neither change has any effect on the results.
I am clearly doing something wrong, and would be grateful for suggestions.
The attached tarball includes the Grid129x129 file and the .xml files for each case, I have also included a plot of my results, in the same format as in the tutorial.
