8.2
cs_matrix_spmv.h
1 #ifndef __CS_MATRIX_SPMV_H__
2 #define __CS_MATRIX_SPMV_H__
5  * Sparse Matrix-vector multiplication functions and kernels.
31  * Local headers
34 #include "cs_defs.h"
36 #include "cs_halo.h"
37 #include "cs_numbering.h"
38 #include "cs_matrix_priv.h"
39 #include "cs_matrix_assembler.h"
46  * Macro definitions
48
50  * Type definitions
52
54  * Global variables
56
57 /*=============================================================================
58  * Semi-private function prototypes
59  *============================================================================*/
60
61 /*----------------------------------------------------------------------------
62  * Assign default sparse matrix-vector product functions for a given matrix.
63  *
64  * parameters:
65  * m <-> pointer to matrix structure
66  *----------------------------------------------------------------------------*/
67
68 void
70
71 /*----------------------------------------------------------------------------
72  * Select the sparse matrix-vector product function to be used by a
73  * matrix or variant for a given fill type.
74  *
75  * Currently, possible variant functions are:
76  *
77  * CS_MATRIX_NATIVE (all fill types)
78  * default
79  * baseline
80  * omp (for OpenMP with compatible numbering)
81  * omp_atomic (for OpenMP with atomic add)
82  * vector (For vector machine with compatible numbering)
83  * cuda (CUDA-accelerated)
84  *
85  * CS_MATRIX_CSR (for CS_MATRIX_SCALAR or CS_MATRIX_SCALAR_SYM)
86  * default
87  * mkl (with MKL)
88  * mkl_sycl (with MKL, using SYCL offload)
89  * cuda (CUDA-accelerated)
90  * cusparse (with cuSPARSE)
91  *
92  * CS_MATRIX_MSR
93  * default
94  * omp_sched (Improved OpenMP scheduling, for CS_MATRIX_SCALAR*)
95  * mkl (with MKL)
96  * mkl_sycl (with MKL, using SYCL offload)
97  * cuda (CUDA-accelerated)
98  * cusparse (with cuSPARSE)
99  *
100  * CS_MATRIX_DIST
101  * default
102  * omp_sched (Improved OpenMP scheduling, for CS_MATRIX_SCALAR*)
103  * mkl (with MKL)
104  * mkl_sycl (with MKL, using SYCL offload)
105  *
106  * parameters:
107  * m_type <-- Matrix type
108  * fill type <-- matrix fill type to merge from
109  * spmv_type <-- SpMV operation type (full or sub-matrix)
110  * (all types if CS_MATRIX_SPMV_N_TYPES)
111  * numbering <-- mesh numbering structure, or NULL
112  * func_name <-- function type name, or NULL for default
113  * spmv <-> multiplication function array
114  * spmv_xy_hd <-> multiplication function x and y host/device location
115  *
116  * returns:
117  * 0 for success, 1 for incompatible function, 2 for compatible
118  * function not available in current build
119  *----------------------------------------------------------------------------*/
120
121 int
123  cs_matrix_fill_type_t fill_type,
124  cs_matrix_spmv_type_t spmv_type,
125  const cs_numbering_t *numbering,
126  const char *func_name,
127  cs_matrix_vector_product_t *spmv[CS_MATRIX_SPMV_N_TYPES],
128  char spmv_xy_hd[CS_MATRIX_SPMV_N_TYPES]);
129
130 /*======================================à=======================================
131  * Public function prototypes
132  *============================================================================*/
133
135
137
138 #endif /* __CS_MATRIX_SPMV_H__ */
Definition: cs_defs.h:528
Definition: cs_defs.h:529
Definition: cs_matrix.h:95
@ CS_MATRIX_SPMV_N_TYPES
Definition: cs_matrix.h:100
Definition: cs_matrix.h:110
Definition: cs_matrix.h:72
cs_matrix_type_t
Definition: cs_matrix.h:54
int cs_matrix_spmv_set_func(cs_matrix_type_t m_type, cs_matrix_fill_type_t fill_type, cs_matrix_spmv_type_t spmv_type, const cs_numbering_t *numbering, const char *func_name, cs_matrix_vector_product_t *spmv[CS_MATRIX_SPMV_N_TYPES], char spmv_xy_hd[CS_MATRIX_SPMV_N_TYPES])
Definition: cs_matrix_spmv.cpp:3970
void cs_matrix_spmv_set_defaults(cs_matrix_t *m)
Definition: cs_matrix_spmv.cpp:3891
Definition: cs_numbering.h:87
