Use Case
When CFD results from another tool are available, they may be used to initialize a code_saturne computation using the MEDCoupling remapper tools. For more information on MEDCoupling features, see https://docs.salome-platform.org/latest/dev/MEDCoupling/tutorial/index.html#english-toc
This requires that:
code_saturne is installed with MEDCoupling
- MEDCoupling is installed with MED file support (which is the default configuration).
- The provided data is in MED format or at least in a format supported by ParaView.
If the previous results are provided in another format than MED, they can be converted using the SALOME platform's PARAVIS module, which is an extension to ParaView including several plugins, especially a MED reader and writer. All that is required is to read the results in PARAVIS, then save them to MED format them using the "Save Data" option from ParaView's "File" menu. This can also be done using ParaView scripts if preferred.
Example code
The following example shows how to read fields from a MED file using MEDCoupling remapper features.
The field_names array here contains the list of fields we plan to read and their matching names in the MED file.
The file_name should reference a file relative to the run directory, using either a proper relative path or an absolute path (as usual, if the file is placed in a case's DATA directory, it will automatically be copied to the execution directory, but this leads to additional copies of possibly large data).
In this example, we also force the remapper option to PointLocator (see INTERP_KERNEL::PointLocator in MEDCoupling documentation). By default, code_saturne uses INTERP_KERNEL::Triangulation, which allows for better conservation of quantities, but is slower.
if (domain->time_step->nt_prev > 0)
return;
#if defined(HAVE_MEDCOUPLING_LOADER)
bft_printf(
"In cs_user_initialization HAVE_MEDCOUPLING_LOADER\n");
const int nremapper_fields = 2;
const char *field_names[] = {"p", "U"};
if (r == NULL) {
int elts_dim = 3;
int it0 = 0, it1 = 0;
const char file_name[] = "../../../MESH/channel395_OF_4.1_5000.med";
elts_dim,
"all[]",
file_name,
nremapper_fields,
field_names,
it0,
it1);
"IntersectionType",
"PointLocator");
for (int f_id = 0; f_id < nremapper_fields; f_id++) {
if (f_id == 0) {
for (
cs_lnum_t c_id = 0; c_id < n_cells; c_id++) {
cvar_p[c_id] = m_vals[c_id];
else if (f_id == 1) {
for (
cvar_vel[c_id][0] = m_vals[c_id*3];
cvar_vel[c_id][1] = m_vals[c_id*3 + 1];
cvar_vel[c_id][2] = m_vals[c_id*3 + 2];
bft_printf(
"Time in MEDCoupling: %f seconds \n", t2 - t1);
#endif
#define BFT_FREE(_ptr)
Free allocated memory.
Definition: bft_mem.h:101
Definition: bft_printf.c:140
int bft_printf_flush(void)
Flush for output of bft_printf() with modifiable behavior.
Definition: bft_printf.c:169
Definition: cs_defs.h:319
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:332
Definition: cs_defs.h:313
@ p
Definition: cs_field_pointer.h:67
@ vel
#define CS_F_(e)
int cs_medcoupling_remapper_initialize(const char *name, int elt_dim, const char *select_criteria, const char *medfile_path, int n_fields, const char **field_names, int iteration, int order)
initialize a remapper based on a set of given arguments
Definition: cs_medcoupling_remapper.cxx:679
void cs_medcoupling_remapper_set_options(cs_medcoupling_remapper_t *r, const char key[], const char value[])
set non-default options for a remapper
Definition: cs_medcoupling_remapper.cxx:754
cs_medcoupling_remapper_t * cs_medcoupling_remapper_by_id(int r_id)
get a remapper by its id
Definition: cs_medcoupling_remapper.cxx:613
cs_real_t * cs_medcoupling_remapper_copy_values(cs_medcoupling_remapper_t *r, int field_id, double default_val)
Interpolate values for a given field.
Definition: cs_medcoupling_remapper.cxx:856
cs_medcoupling_remapper_t * cs_medcoupling_remapper_by_name_try(const char *name)
get a remapper by its name
Definition: cs_medcoupling_remapper.cxx:640
void cs_medcoupling_remapper_setup(cs_medcoupling_remapper_t *r)
update the interpolation matrix of the remapper
Definition: cs_medcoupling_remapper.cxx:816
struct _cs_medcoupling_remapper_t cs_medcoupling_remapper_t
Definition: cs_medcoupling_remapper.h:44
double cs_timer_wtime(void)
Return Wall clock time.
Definition: cs_timer.c:491
cs_lnum_t n_cells
Definition: cs_mesh.h:97
Note that we do not need to specify the field dimensions here, but they should match, so mapping a vector field to a scalar will produce a crash.
