Syrthes - Code_Saturne coupling problem
stefann
Post by stefann »
I installed code_saturne 4.0.0 and syrthes 4.3.0 together. Each code works individually but when I try to couple them together I get the following error:
 Single processor SYRTHES simulation.
  Preparing calculation data
  File "/usr/local/bin/code_saturne", line 76, in <module>
    retcode = cs.execute()
  File "/usr/local/lib/python2.7/dist-packages/code_saturne/cs_script.py", line 88, in execute
  File "/usr/local/lib/python2.7/dist-packages/code_saturne/cs_script.py", line 150, in run
  File "/usr/local/lib/python2.7/dist-packages/code_saturne/cs_run.py", line 304, in main
    save_results=save_results)
  File "/usr/local/lib/python2.7/dist-packages/code_saturne/cs_case.py", line 1717, in run
    force_id)
  File "/usr/local/lib/python2.7/dist-packages/code_saturne/cs_case.py", line 1444, in prepare_data
    d.prepare_data()
  File "/usr/local/lib/python2.7/dist-packages/code_saturne/cs_case_domain.py", line 1124, in prepare_data
    raise RunCaseError("Cannot locate SYRTHES installation.\n")
cs_case_domain.RunCaseError: Cannot locate SYRTHES installation.
I have checked if SYRTHES4_HOME is in my path:
echo $SYRTHES4_HOME
/opt/syrthes4.3.0/arch/Linux_x86_64
My /usr/local/etc/code_saturne.cfg file has:
[install]
syrthes = /opt/syrthes4.3.0/arch/Linux_x86_64
[run]
Any ideas why it cannot find the syrthes installation?
Stefan
Re: Syrthes - Code_Saturne coupling problem
Is this a case created under version 4.0 or converted from another version ?
What is in your runcase and coupling_parameters.py file ?
stefann
Post by stefann »
I used the code_saturne cmd to create the study/case:
code_saturne create --study 3disks2D --case case1
Then I copied the files from the code_saturne-4.0.0/examples/4-2Ddisks/case1/solid to their respective directories (per the coupling tutorial).
The runcase file I assume was created automatically when the study/case was created:
#!/bin/bash
export PATH=/usr/local/bin:$PATH
# Run command:
\code_saturne run --coupling coupling_parameters.py
The coupling_parameters.py file I have tried the default sys.path which is '<code_saturne.cfg/syrthes>' and I have also tried the actual location of my syrthes installation:
# -*- coding: utf-8 -*-
# User variable settings to specify a coupling computation environnement.
# A coupling case is defined by a dictionnary, containing the following:
# Solver type ('Code_Saturne', 'SYRTHES', 'NEPTUNE_CFD' or 'Code_Aster')
# Domain directory name
# Run parameter setting file
# Number of processors (or None for automatic setting)
# Optional command line parameters. If not useful = None
# Ensure the correct SYRTHES install is used.
#sys.path.insert(1, '<code_saturne.cfg/syrthes>')
sys.path.insert(1, '/opt/syrthes4.3.0/arch/Linux_x86_64')
# Define coupled domains
domains = [
    {'solver': 'Code_Saturne',
     'domain': 'fluid',
     'script': 'runcase',
     'n_procs_weight': None,
     'n_procs_min': 1,
     'n_procs_max': None}
    {'solver': 'SYRTHES',
     'domain': 'solid',
     'script': 'solid-coupling.syd',
     'n_procs_min': 1,
     'n_procs_max': None,
     'opt' : '-v ens'}         # Additional SYRTHES options
                               # (ex.: postprocessing with '-v ens' or '-v med')
In the coupling_parameters.py file, could you try ?
sys.path.insert(1, '/opt/syrthes4.3.0/arch/Linux_x86_64/share/syrthes')
instead of
Still, this should be automatic. Another user has also reported a similar issue, but I have not been able to reproduce it on my side, so it must be subtle (it might be related to installing Code_Saturne in /usr/local instead of a user directory (as the path does not need to be modified), but I am not sure.
I'll try to make things more verbose in version 4.0.1 to help debugging this sort of issue.
stefann
Post by stefann »
Thanks. That got me past the path not found error.
However, I am using the example files directly from the code_saturne example directory and the coupled case doesn't run. The individual cases (fluid and solid), individually, work fine.
In the RESU_COUPLING/2015......./ directory the summary file says "solver failed"
In the /fluid directory, the error file is empty, the listing file has no error or fail listed anywhere. It makes it as far as MAIN CALCULATION and nothing afterwards.
In the /solid directory, the syrthes.log file has:
*** READING THE VOLUMIC CONDITIONS IN THE DATA FILE
        --> No constant volumic source term is present in the data file
 CFD COUPLING INITIALIZATIONS
  coupling 0: initializing MPI communication ...
CFD coupling: local_ranks =                 [0..0]
              distant ranks =               [1..1]
              communication scheme version: 2
              conservativity flag:          0
              allow nonmatching:            0
              tolerance:                    0      0.1
Cfd struct
  app_num:       -1
  do_coupling:     1
  coupl_surf :     1
  coupl_vol  :     0
  n_couplings:     1
      Code_Saturne
[ubuntu:03033] *** Process received signal ***
[ubuntu:03033] Signal: Segmentation fault (11)
[ubuntu:03033] Signal code: Address not mapped (1)
[ubuntu:03033] Failing at address: 0x50
[ubuntu:03033] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0x10340)[0x7f5180c28340]
[ubuntu:03033] [ 1] ./syrthes[0x41d602]
[ubuntu:03033] [ 2] ./syrthes[0x414054]
[ubuntu:03033] [ 3] ./syrthes[0x40a97b]
[ubuntu:03033] [ 4] ./syrthes[0x402c6f]
[ubuntu:03033] [ 5] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7f5180874ec5]
[ubuntu:03033] [ 6] ./syrthes[0x402e95]
[ubuntu:03033] *** End of error message ***
I compiled both code_saturne and syrthes with openmpi version 1.8.3, both codes can run with openmpi and multiple cores activated.
Any ideas? I think its been over a year since I have been able to run coupled codes together.
It isn't very easy to get them to play nice with each other!
Stefan
In this case, it seems it is Syrthes which crashes very early on. We have reported a bug to the Syrthes developers relative to a crash at the end of the Syrthes run, so this migh be the same bug of either Code_Saturne or Syrthes requested no iterations.
Otherwise, without the data to run your case, I have no idea what might be wrong.
