mei_evaluate.c:392: Fatal error.
Claws
Post by Claws »
Im trying to run a natural convection simulation using CS 3.0.0 in CAELinux Live (so I can't install a new vers.)
If I use the following user law for density:
rho = 1.293 * (273.15 / TempC + 273.15);
Code_Saturne crashes with the following error:
INSTANT    0.100000000E-02   TIME STEP NUMBER               1
Error: floating point exception
   1: 0x7fb17f27b9b2 <+0x5269b2>                      (libsaturne.so.0)
   2: 0x7fb17f27b8b0 <+0x5268b0>                      (libsaturne.so.0)
   3: 0x7fb17f27b64a <+0x52664a>                      (libsaturne.so.0)
   4: 0x7fb17f27b689 <+0x526689>                      (libsaturne.so.0)
   5: 0x7fb17f1d8ac5 <uiphyv_+0x18f5>                 (libsaturne.so.0)
   6: 0x7fb17eebcf9c <phyvar_+0x2fc>                  (libsaturne.so.0)
   7: 0x7fb17eeee95a <tridim_+0xd8a>                  (libsaturne.so.0)
   8: 0x7fb17edce834 <caltri_+0x30e0>                 (libsaturne.so.0)
   9: 0x7fb17eda5125 <cs_run+0xa35>                   (libsaturne.so.0)
  10: 0x7fb17eda460a <main+0x14a>                     (libsaturne.so.0)
  11: 0x7fb17e79976d <__libc_start_main+0xed>         (libc.so.6)
  12: 0x4006c9     <>                               (cs_solver)
Without the user law, the simulation runs fine.
What is the problem here? The user law works fine on my workstation at home with vers. 3.2
/C
Re: mei_evaluate.c:392: Fatal error.
The fact that the crash is due to a floating point exception suggests that it might be due to incorrect (extreme) values of TempC rather than a bug in the MEI expression evaluation itself (either that, or the wrong type of error is reported).
Checking the NEWS file in the 3.0 branch, I didn't fint any specific fix between 3.0 and 3.0.4 (next release), but the fact that it occurs at the first time step indicates it might be related to initialization.
With a version you compiled yourself, I could suggest various debugging strategies (starting with upgrading to 3.0.3), but with a fixed, preinstalled (and, I assume production-rather-than-debug build), options are more limited. In case the bug is initialization-related, either using a user subroutine for initialization, or running a few time steps without the MEI expression than doing a restart with it.
Claws
Post by Claws »
Missing parentheses can lead to problems... :oops:
rho = 1.293 * (273 / (TempC+273))
I really wish CS was better at reporting errors :)
/C
