Re: Guide to couple Saturne & SYRTHES
Posted: Tue Apr 21, 2015 9:20 am
The guide needs to be updated, as both Syrthes and Code_Saturne need the PLE library to be installed first. As that library is part of Code_Saturne, it is easier to simply install Code_Saturne first. Another option is to install PLE first, by running a configure/make/make install sequence relative to Code_Saturne's libple subdirectory; in that case, you may then install Code_Saturne (configuring with --with-ple=) and Syrthes in any order.
In any case, if there is a contradiction between an old post on the forum and the (normally) up to date installation manual, choose the documentation (and if that is false, we'll fix it).
