looking for cases with coupled calculations CS-2.0-rc2 and Syrthes
Kathi Blum
Post by Kathi Blum »
are there tuts for a coupled CS/Syrthes calculation for cs-2.0-rc2 available? The tuts for the older version contain also a simail mesh, which I'm not able to read. I want to study the meshtopology of the fluid-, conduction- and radiationmesh to understand how the coupling works. Are there any people, who have working coupled cases with meshes which can be read with Salome or gmsh? I'm interested in the topology of the groups.
Thank you very much!
Kathi
Claus Andersen
Re: looking for cases with coupled calculations CS-2.0-rc2 and Syrthes
Post by Claus Andersen »
I've uploaded one of the tests I did awhile back - coupling of CS and SYRTHES, no radiation though.
I never got around to writing an introduction for CS/S when I tried it out first time, so you will have to read the (very good) documentation that comes with SYRTHES and you can use my files to get it up and running quickly.
I will write something about CS/SYRTHES when the new version comes out (which is soon I heard).
Hope it helps a bit :)
Claus
OnePin_example-tar.gz
(6.96 MiB) Downloaded 359 times
Kathi Blum
Thank you, Claus - it works & it helps me to understand.
(dummy)question: is there a way to calculate (and postprocess) the local heat exchange coefficients on the tubes?
regards, Tom
Claus Andersen
Hi Kathi/Tom - I asked a similar question in this thread
https://code-saturne.info/products/code-saturne/forums/general-usage/10359578
Read on from post 10, it explains the difficulties in deriving the heat.ex.coeff - I never got around to formulate how I'd like it calculated.
Claus
