PyQt4 problem
Christine Leroy
PyQt4 problem
Post by Christine Leroy »
Hi !!!
I've been trying to install Saturne in many different ways, but at the end, when compiling ncs, I always have the same message:
configure: error: in `/home/leroy/SATURNE/ncs-2.0.3.build':
configure: error: cannot find PyQt4 support (>= 4.3), Graphical User Interface cannot be installed See `config.log' for more details
 but if I check for PyQt4, I have the following message :
[root@mediceo6NB ncs-2.0.3.build]# yum install PyQt4
Loaded plugins: presto, refresh-packagekit
Setting up Install Process
Package PyQt4-4.7.3-1.fc12.x86_64 already installed and latest version Nothing to do
PS: I've attached to this message the config.log
I am working with Fedora 12
Any help would be nice !!!
Thank you
Christine
config.log
(106.86 KiB) Downloaded 502 times
Re: PyQt4 problem
You need PyQt4-dev also (it might be named slightly differently, such as -devel instead of -dev, depending on your distribution).
Christine Leroy
Re: PyQt4 problem
Thanks a lot for your reply.
(I stay with english as it can be of help for other people).
I've tried to install the dev package....but still have the same answer :
[root@mediceo6NB leroy]# yum install PyQt4-devel
Package PyQt4-devel-4.7.3-1.fc12.x86_64 already installed and latest version
Nothing to do
I also tried again the installation of ncs, and I still have the same error message concerning PyQt4.
I really don't know how to proceed.
What is PyQt4 used for?
As it seems to be in my computer, maybe there could be a problem, such as Saturne is not able to find it and I should change something in the  "PATH" or other things like this, but I'm not a Linux specialist and I have no idea...
Christine
Re: PyQt4 problem
Looking at your config.log, it seems that you have a second installation of Python in /usr/local, so it is probable that the PyQt4 and PyQt4 packages only work with the python version from /usr (Note that /usr/local takes priority over /usr, but you should only have locally installed packages under /usr/local).
You should try to add
--with-python_exec=/usr/bin
to the configure command for Code_Saturne, to try to use the reference Python version (assuming /usr/bin/python exists, but the contrary would be surprising).
Christine Leroy
Re: PyQt4 problem
I've done what you wrote and it worked, thank you so much !!!
I've been trying for 2 weeks to install the code....I had many errors I could deal with, but with this one, I really couldn't do anything !!!!
Now I have to add something to the PATH I think.
I just have to write in a shell
export PATH=/root/opt/ncs-2.0.3/bin:$PATH
then to run the program : code_saturne
again, thank you so much
Christine
Re: PyQt4 problem
Hello again,
Yes, you can either add the Code_Saturne bin directory in your path, or simply define an alias:
alias code_saturne=/root/opt/ncs-2.0.3/bin/code_saturne
(or even simply use the full path to code_saturne).
For additional comfort (if you are using a bash shell), you may also add:
source /root/opt/ncs-2.0.3/etc/bash_completion.d/code_saturne
to obtain a semi-automatic bash completion for Code_Saturne commands and their options.
Christine Leroy
Re: PyQt4 problem
Oups,
sorry, but I'm lost....
the "code_saturne" is in :  /root/opt/cs-203/bin
so I did :
alias code_saturne=/root/opt/cs-203/bin/code_saturne
but when I call the program, I have :
[leroy@mediceo6NB bin]$ code_saturne
bash: /root/opt/cs-203/bin/code_saturne: Permission denied
probably because I can't go into root if I'm not root....so I logged as root,and had the following answer :
[root@mediceo6NB bin]# code_saturne
Command not found.
in the directory:
/home/leroy/SATURNE/ncs-2.0.3.build/bin, I also have a file code_saturne, but it's not green as any program.....
PS: for installing the program, I followed the instruction of the README.txt of the installer, so I create for every module an other module.build ( for example : ncs-2.0.3.build) from which I launched the command fo compiling, and I did everything logged as root.
I also tried with export PATH etc....but, no more results.
With Regards
Christine
Re: PyQt4 problem
I confirm that /root is accessible only to the root account, so if you install the code under /root, it will not be usable (not accessible, so not found) from other accounts. If you defined the alias before logging as root, it will not work either (you need to define it when logged as the user who will run the code, unless you define it in /etc/bash.bashrc or some equivalent path under /etc).
You should either (depending on whether the install is for multiple users or not):
  • install as root under another prefix (/opt/saturne/2.0 or /usr/local for example)
    install as a regular user, for example /home/leroy/Code_Saturne/2.0.
The code_saturne script you have under /home/leroy/SATURNE/ncs-2.0.3.build is not executable, as it has only been built (result of configure and make), not installed (the following stage, "make install"). When installing, some path variables are replaced by the destination paths, and the script is made executable).
Christine Leroy
Re: PyQt4 problem
ciao Yvan,
thanks a lot for your reply.
In the meantime, I've reinstalled the code but not in the /root/opt directory...in another prefix (I hope I use the right term) : /home/leroy/software/saturne/cs-203
but i'm still not able to run it with the alias even if i did it as root. I works the first time then it writes :
bash: /home/leroy/SATURNE/ncs-2.0.3.build/bin/code_saturne: Permission denied
this corresponds to the previous installation. I cancelled in the bash file but the problem stills remains.
So I did :
[root@mediceo6NB leroy]# echo 'export PATH=$PATH:/home/leroy/software/saturne/cs-203/bin/code_saturne' >> /home/leroy/.bashrc
[root@mediceo6NB leroy]# code_saturne
Usage: /home/leroy/software/saturne/cs-203/bin/code_saturne <topic>
Topics:
help
check_consistency
check_mesh
compile
config
create
gui
info
plot_probes
Options:
  -h, --help  show this help message and exit
[root@mediceo6NB leroy]# exit
exit
[leroy@mediceo6NB ~]$
[leroy@mediceo6NB ~]$ code_saturne
bash: /home/leroy/SATURNE/ncs-2.0.3.build/bin/code_saturne: Permission denied [leroy@mediceo6NB ~]$ vi /home/leroy/.bashrc
  !  I've checked here and the path is ok
[leroy@mediceo6NB ~]$ vi /home/leroy/.bash_profile
! also here
even if I log as root...
[root@mediceo6NB leroy]# code_saturne bash: /home/leroy/SATURNE/ncs-2.0.3.build
it remains on the old installation...maybe because I also tried with "source" before and I don't know how to cancel what i did then. But I tried to do it again with the good prefix and I obtained:
[root@mediceo6NB leroy]# source /home/leroy/software/saturne/cs-203/etc/bash_completion.d/code_saturne
bash: /home/leroy/software/saturne/cs-203/etc/bash_completion.d/code_saturne: line 58: syntax error in conditional expression:
unexpected token `('
bash: /home/leroy/software/saturne/cs-203/etc/bash_completion.d/code_saturne: line 58: syntax error near `@(-'
bash: /home/leroy/software/saturne/cs-203/etc/bash_completion.d/code_saturne: line 58: `    if [[ ${prev} == @(-h|--help|-v|--version) ]]; then'
The good point is that I can launch the program if I write the entire path !!! I can't tell at this point if it works ok, I've never used it before. By the way, I was looking for Tutorial. I just found a tutorial.pdf but no files with the mesh etc... have you any idea where I cold find this?
Best Regards
Christine
Christine Leroy
Re: PyQt4 problem
Yvan,
PS : ok for the Tutorial, I think I found something in the cs-203/..../ncs directory, even if not able to launch anything at the moment....maybe because I can't open Saturne normally but still with all the all address (/home/leroy/.../code_saturne) so I can't launch commands maybe...
Christine
