Dear All,
after selecting the "start calculation" button, I find some problems in the calculation:
Here below you can see which errors are displayed:
Could you please tell me how to manage these issues?
Thank you
File "C:\Python27\lib\site-packages\cx_Freeze\initscripts\Console.py", line 27, in
File "bin/code_saturne", line 76, in
File "lib/python2.7/site-packages/code_saturne\cs_script.py", line 88, in execute
File "lib/python2.7/site-packages/code_saturne\cs_script.py", line 150, in run
File "lib/python2.7/site-packages/code_saturne\cs_run.py", line 304, in main
File "lib/python2.7/site-packages/code_saturne\cs_case.py", line 1760, in run
File "lib/python2.7/site-packages/code_saturne\cs_case.py", line 1500, in prepare_data
File "lib/python2.7/site-packages/code_saturne\cs_case_domain.py", line 758, in preprocess
File "lib/python2.7/site-packages/code_saturne\cs_exec_environment.py", line 517, in run_command
File "C:\Python27\lib\subprocess.py", line 710, in __init__
_active.append(self)
File "C:\Python27\lib\subprocess.py", line 958, in _execute_child
if self.stdin:
Error launching start calculation
Re: Error launching start calculation
Could you also provide the other info recommended by this Forum's usage guidelines.
I guess you are running Windows, but don't know which version, and which Code_Saturne version.
This might be related to the following issue: http://code-saturne.org/forum/viewtopic.php?f=2&t=1812
so the workaround there should work for you (if not, it means it is a different issue, so I'm interested in your feedback in any case).
I have Windows 7 Professional.
Unfortunately I could not open the link reported in your answer,as it refers to the same message I have posted. Is it the correct link?
Thank you again.
Thank you again.
Sorry, here is the correct url: http://code-saturne.org/forum/viewtopic.php?f=2&t=1799
Which version of Code_Saturne are you using ?
