If you want to specified an initial mesh_displacement (for an initial water elevation), you can do it in cs_user_initialization. The boundary condition imposed in case of free surface is an imposed pressure (at p0) and an homogeneous Neumann on the fluid velocity (so no additional shear stress due to wind for instance) and an imposed mesh velocity (equal to the fluid velocity for the normal component to the surface).
I hope it will help you
Martin
subroutine not over-riding GUI boundary conditions - ALE
Re: subroutine not over-riding GUI boundary conditions - ALE
Hi Martin,
So I should be able to do this by building a mesh that is initially deformed. As long as I specify the correct gravity vector and all touching sides as sliding?
I have tried with initialising my volume with the velocity field to be expected under a standing wave. Or with no initialisation.
I tried with the mesh viscosity at a minimum.
No matter what I do I cannot get the 'free surface' to deform.
I currently dont have access to the subroutines, or at least when I try and use them I get a lot of library errors. So if you think the above should work then I would appreciate if you have time to take a look at my setup and see if you can see what I am doing wrong!
- standingwave.med.tar
- (1.01 MiB) Downloaded 216 times
- free_surface.xml
- (7.51 KiB) Downloaded 219 times
You can specify the initial water elevation by modifying this vectorial field in cs_user_initialisation.f90. Then, by default, a imposed pressure is imposed at the free surface (with p0 value) and a homogeneous Neumann on the velocity. Concerning the mesh velocity, the normal component to the free surface is imposed so that it compensates the mass flux (and then it is concervative in fluid mass). By default no shear stress is imposed at the free surface.
Martin
Martin
Could you let me know what the variable is that lets me set the initial displacement? I have tried depale and disale, but cannot get either to work. I know xstr0/xtreq are used to specify initial mesh displacement for internal coupling but I am not using this here.
I have attached my xml, mesh and cs_user_initialization file. I am using v4.03 on a mac.
Thanks in advance,
Thanks in advance,
- 2d_box_sloshing_cozzithesis.med.zip
- (1.04 MiB) Downloaded 201 times
- SloshingGUI.xml.zip
- (2.04 KiB) Downloaded 200 times
- cs_user_initialization.f90.zip
- (2.25 KiB) Downloaded 205 times
