GUI setup of a turbomachinery model
ffan
Post by ffan »
Dear Code_Saturne users and developers,
Code_Saturne version 4.0 has turbomachinary model available in GUI. It would be really nice to have an example of GUI setup of a complete turbomachinary model. Thanks.
- ffan
Re: GUI setup of a turbomachinery model
I encourage other users to also contribute examples.
I'll be off-line most of next week, but when I return, I'll try to remember to check with others whether we should add an "examples" section in the forum (as we had in its old incarnation).
In the meantime, I'll post two xml files from our verification test suite. You can adapt it to your case.
radial_flow_frozen.xml
(6.62 KiB) Downloaded 767 times
radial_flow_transient.xml
(6.62 KiB) Downloaded 802 times
ffan
Post by ffan »
Thank you Yvon. If Code_Saturne can publish its test cases, they would be very helpful as examples. (Code_Aster publishes its test cases for people to use as examples.)
- ffan
Yes, I agree, but we still need to sort out which subset of the test case can be published (most cases are not confidential, but there is quite a bit of experimental data which we are not free to publish, and as the validation base is regularly updated, we need to work on automated extraction of the publishable part)...
ffan
Post by ffan »
Yes, there are some test cases in Code_Aster that are blocked out also.
- ffan
